-   -   Led lights... big diffrence (http://www.mariahownersclub.com/forum/original-mariah-talk/11037-led-lights-big-diffrence.html)
tpdtopcop 04-04-2017 10:10 PM
Re: Led lights... big diffrence
Thanks for posting. I have a 1996 Z255 Shabah and was wondering what led's will fit in the cuddy?
tpdtopcop 04-04-2017 10:14 PM
Wonder what the difference between 5th and 6th generation is?
elrack 04-05-2017 11:53 AM
It appears the 6th gen are brighter and 2mm longer.
tpdtopcop 04-05-2017 05:08 PM
will they fit then or not?
pllevine 04-05-2017 09:36 PM
They don't fit
tpdtopcop 06-04-2017 10:17 PM
Originally Posted by Hunter12345 (Post 61104)
http://uploads.tapatalk-cdn.com/2016...e0148749f4.png
Are these the ones?
'98 mariah shabah 180
5.7l 350 mag
Bravo III
I put these in cuddy and not one of them worked. I then replaced one the the curtesy lights by rear seat and it would not fit in the holder all the way. Anyone else had this problem?
Firestone 06-05-2017 12:23 AM
Ugggg. Let us know what you end up with. LED lights are my next upgrade
pllevine 06-05-2017 12:51 AM
I had that VERY issue. The LED arrayed light bulbs would not fit in the stock fixtures because they were too long.....
So, with a sigh, I ordered new LED based 194 bulbs that are the same length and shape of the standard 194 bulb....
If the bulbs that you bought wouldn't light up, then you should turn the bulb 180 degrees.
tpdtopcop 06-05-2017 12:21 PM
Thanks for the reply. What LED based 194 bulbs did you end up going with?
