Can i fit a sub in rear bench facing forward?
Old 08-03-2016, 01:27 AM   #11
Bdbwtie is currently offline
Send Bdbwtie:
Default Re: Can i fit a sub in rear bench facing forward?
Originally Posted by CHICKS75 View Post
I have a Kicker marine 12" composite sub box in this area. 12" Kicker CVx12, 1000 watt kicker amp.
The sound is crystal clear @ 30 and makes most tower systems sound radio shack...
Total of 10 speakers / 4 - 6" mids, 4 - tweeters, 2 - 8" coaxials, 1 - 12" sub.
Any idea where you got that sub box from? Cant come up with anything.
I do currently have 2 8" subs in that location. Of course they are blown, so perfect time to upgrade right. My thinking for putting them under the bench was because for me, the rear compartment next to the motor would be more usable than under the bench seats. And it seems as the extra heat put off from the engine wouldn't be good for subs?
I have 2 6.5 clarions mounted forward facing in the rear bench currently. We haven't had any issues or close calls with damage or puncturing them so far. I would assume that subs with a grill guard would be fine.??
  • Old 08-03-2016, 03:58 PM   #12
    CHICKS75's Avatar
    CHICKS75 is currently offline
    Status: I got this...
    My Model: 210 Z L.E. SHABAH
    My Engine: 5.7 Alpha-One Gen II
    Gallery Images: 15
    Send CHICKS75:
    I couldn't either, I could find the 10" size. They might be dealer supplied only?
    I asked the same thing and he told me the Kickers are designed for extreme conditions. but as i look at it that area sees a lot of air flow when driving and when still the motor doesn't put that much heat in those areas on mine.
    For my thought process, if I have issues and don't like the sound i could always move it to the bench area as discussed, but I've been very happy these past two years.
    Please keep us informed on what you do and post some pictures..
    http://www.hifisoundconnection.com/K...e-Box-MS-R-CVX
    1998 Shabah 210Z L.E.
    5.7L Alpha-One, Gen II
    Thank you CHICKS75 for this useful post!
    Firestone (08-03-2016)
    Old 08-03-2016, 09:10 PM   #13
    tdicamillo is currently offline
    My Model: Z222 Shabah
    My Engine: 7.4L Bravo I
    Send tdicamillo:
    Yes it can be done. I believe the 202 is a little narrower then my Z222 but you should have at least 3 Cu. Ft. of space to work with in your bench. A typical 10" in a ported box (deeper base) uses ~ 1.5 Cu. Ft. and a sealed box (better punchy sound) typically consumes .8 - 1.25 Cu. Ft.
    I have a 1999 Z222 Shabah and converted the bench seat into a speaker box. The prior owner had 2 - 12" JL Audio subs stuffed in the back hatch that was very muffled. I took them out and built 2 boxes that I slipped inside the bench that hold 2 10's instead. Not wanting to have the speakers exposed to the elements, baking sun in AZ, or feet kicking them when someone is sitting on the bench I designed the boxes to fire up towards at the bottom of the seat. The cut a couple of rectangle openings with some SS mesh for the sound to come out of and used a 3" hole saw and ran the ports thought the base of the bench. With the bench seat closed there is about 3" of clear space to the bottom of the seat. These 10's are much louder and cleaner sounding then the 2 - 12" that where stuck in the back hatch even thought they a little smaller. FYI the 10's are Rockford Fosgate Prime. The only reason I selected them is the local shop had them miss priced and I picked up the pair for$120.00.
    Hope this gives you some ideas.
    If you need advice or help PM me. I used to do audio competition and worked building custom boxes in AZ when I was younger. So be more that happy to share the knowledge.
    Tom
    pllevine, Firestone and Bdbwtie like this.
    The Following 2 Users Say Thank You to tdicamillo For This Useful Post:
    Firestone (08-03-2016), pllevine (08-17-2016)
    Old 08-03-2016, 10:11 PM   #14
    My Model: Z202
    Send Firestone:
    Nice! Thanks. Looks like a rocking set up
    John
    Custom Rear bench subwoofer enclosure John Rush Projects 14 05-07-2015 10:43 PM
    bench hinges tfn1977 Original Mariah Talk 11 10-31-2011 09:05 PM
    forward in reverse karae225 Mercury MerCruiser 4 06-15-2010 10:21 PM
    Control arm not shifting out of forward Lunaticutah Original Mariah Talk 3 06-26-2009 04:14 PM
    Bench Seat Hinges Kuli Original Mariah Talk 1 05-01-2008 12:33 PM
    Total Members: 18,990
    Total Threads: 13,324
    There are 235 users
