Vinyl coming away from fiberglass
Old 07-30-2016, 07:43 PM   #1
mike523 is currently offline
My Model: Talari
My Engine: 4.3 Mercruiser
Send mike523:
Default Vinyl coming away from fiberglass
What to do about this?
  • Old 07-31-2016, 12:55 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Vinyl coming away from fiberglass
    Having the same problem in a few spots
    mike523 likes this.
    John
    Old 08-04-2016, 03:57 PM   #3
    My Model: Z276
    Send Brian Belcher:
    Are screws holes stripping ?
    (there's so much smut in my question)
    Old 08-04-2016, 03:58 PM   #4
    My Model: Talari
    Send mike523:
    lol yeah they must be
    Old 08-04-2016, 03:58 PM   #5
    My Model: Z202
    Send Firestone:
    I know they are in my boat, any advice on what to use to fix it?
    John
    Old 08-04-2016, 04:16 PM   #6
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Remove the stripped screws and use the next larger dia./size.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Firestone (08-04-2016)
    Old 08-04-2016, 04:21 PM   #7
    My Model: Talari
    Send mike523:
    Mine is pulling away so hard I can't even push it to fit tight to the fiberglass
    Old 08-04-2016, 04:42 PM   #8
    My Model: Z202
    Send Firestone:
    Thanks Hudson. Being a shade repairman I thought that might work, but I didn't know if that was the best approach.
    John
    Old 08-04-2016, 06:36 PM   #9
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    When I took my side panels off a couple of weeks ago I had a few screws do this. I dabbed some sealant in the hole before putting the screw back in. In a couple of spots I was able to add a chunk of wood behind the screw to suck it in tight.
    Thank you baholtz for this useful post!
    Old 08-04-2016, 06:36 PM   #10
    My Model: Z276
    Send Brian Belcher:
    If u can reach the back side, u may need to use a carriage bolt and washers.
    If you have the room, undo the entire panel and move it fore or aft to gain new holes on all of them. If the boat has shrunk or the panels have grown, you may want to gingerly remove the fabric from one end and cut a 1/2" off.
    Thank you Brian Belcher for this useful post!
    Fiberglass Flooring mark43 Original Mariah Talk 1 09-27-2012 12:52 PM
    Fiberglass or wood stringer? 2000Z272 Original Mariah Talk 7 05-10-2011 03:58 AM
    Meguiars Fiberglass Restoration Kit garyg General Maintenance 3 12-09-2010 09:49 PM
    fiberglass cabinet problems arice Original Mariah Talk 0 05-05-2008 01:45 PM
    Total Threads: 13,324
    There are 313 users
