Ignition buzzer piezzo
Old 07-11-2016, 02:11 AM   #1
wlake73 is currently offline
My Year: 2007
My Model: sx21
My Engine: v-6 alpha I
Send wlake73:
Default Ignition buzzer piezzo
Hi,
I have not posted until now because I have not had any issues.
I'm original owner of an 2007 SX21 V6 Alpha one, with 285 freshwater hours.
Oil changes, fuel filter, lower drive oil, plugs-wires-cap-rotor, ignition switch, & lots of prop rebuilds.
This season when I turned the key, I didn't hear the buzzer. I have a replacement, but can't find the factory location for the broken one. I pulled the switch cluster and it's not behind it. Anyone know where I should look, so that I don't waste more time loosening weak plastic trim with cracked edges/corners?
Jay
646-208-5947
After reading a post discussing a sensor located in the drive lube reservoir, could my buzzer have gone silent because I recently topped off the fluid?
  • Old 07-11-2016, 04:05 AM   #2
    My Model: Z276
    Send Brian Belcher:
    Default Re: Ignition buzzer piezzo
    Mine is behind throttle lever/gear shifter.
    Old 07-11-2016, 12:31 PM   #3
    My Year: 2007
    My Model: sx21
    Send wlake73:
    Does it activate itself in test mode each time the key is turned, or only as a warning from a sensor?
    Jay
    Old 07-11-2016, 12:43 PM   #4
    My Model: Z276
    Send Brian Belcher:
    Every time the key is the run position and engine is dead.
    Old 07-18-2016, 09:06 PM   #5
    jjt1276's Avatar
    jjt1276 is currently offline
    My Model: Shabah 202
    My Engine: 5.0L with Alpha 1
    Send jjt1276:
    The buzzer is behind the throttle. Mine went bad on a 99 this year. It should buzz when the motor is off with key in run position. It also should buzz on low drive oil and over temp when the engine is running. On normal operation the buzz stops when engine is started. There is a chart that tells you the buzzing operation for all motors/out drives. Google it and you should be able to find it.
    Old 07-19-2016, 03:38 PM   #6
    My Year: 2007
    My Model: sx21
    Send wlake73:
    I looked behind throttle this past weekend, and did not see it. Any more ideas, or which wires/circuit does it work with. (I already found the key left in accessory position by someone due to lack of alert)
    jay
    Old 07-20-2016, 07:18 PM   #7
    Not really sure where Sea Fox Mariah installed them.
    Would likely be worth crawling under the dash with a flashlight trying to locate it. It's slightly smaller than a silver dollar, and looks similar to this:
    The alarm circuit only has 3 sensors, drive oil level, engine temperature, and oil pressure. These sensors are marked by a tan wire with blue line on it. You can test the buzzer of the warning system by locating one of these sensors, and running it to a ground. This should activate the alarm.
    jjt1276 likes this.
    Nav Light Power and Warning Buzzer johnserra Original Mariah Talk 6 09-06-2014 08:19 PM
    alarm buzzer jsewall82 Original Mariah Talk 12 06-28-2013 01:02 AM
    Buzzer problem MARIAHSX21 Introductions 2 07-03-2012 12:07 AM
    Buzzer and fuel pump chadh45701 General Maintenance 2 05-22-2010 07:53 PM
    Buzzer location? jkboliphant Original Mariah Talk 3 04-26-2009 12:43 PM
    There are 321 users
