New 1994 Mariah owner need to know model
Old 06-25-2016, 08:40 PM   #1
Mwright is currently offline
My Engine: 5.7 v8
Send Mwright:
Default New 1994 Mariah owner need to know model
We just bought this boat in great shape need to know madel we
Need to find a new trim switch for it
  • Old 06-26-2016, 02:43 AM   #2
    My Model: Z276
    Send Brian Belcher:
    Default Re: New 1994 Mariah owner need to know model
    Sorry but I don't know but I do know the boat is going to self destruct from the picture so please send me your seats.
    ASAP
    Old 06-26-2016, 11:47 AM   #3
    Hunter12345's Avatar
    Status: Silver Contributor
    Gallery Images: 2
    Send Hunter12345:
    Hahaha!
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-26-2016, 12:46 PM   #4
    Gallery Images: 2
    Send Hunter12345:
    You shouldnt have a problem finding one.
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-26-2016, 06:29 PM   #5
    My Model: Z276
    Send Brian Belcher:
    Mright
    Heed this warning !! There is a step by step guide on taking the throttle/gear shifter off so you can get to the trim switch. If you don't follow the steps, you will break the push button that disengages the gear shifter.
    Follow them and do not force or pry on anything
    Thank you Brian Belcher for this useful post!
    Mwright (06-26-2016)
    Old 06-26-2016, 06:35 PM   #6
    My Engine: 5.7 v8
    Send Mwright:
    Would any one have the step by step guid to changing the trim switch and we're might I find a replacement switch
    It goes down but not up and also what do the switches on the dash labeled engine l and trans l do
    Old 06-26-2016, 07:03 PM   #7
    My Model: Z276
    Send Brian Belcher:
    I doubt your switch is the problem. I'd bet 50 cents that your trim sensor on the out drive is out. On the inside of the bilge, on the transom, there is a set of wires, smaller than a lamp cord, that have barrel connectors on it. It passes thru the transom and these are what tell the trim pump to shut off when you hit full up or full down. Disconnect the wires at the barrel connectors and jumper them together. The wires that go to the pump itself. Check your trim now.
    Old 06-26-2016, 07:36 PM   #8
    My Engine: 5.7 v8
    Send Mwright:
    Thanks I will try that I have had it working for a brief moment
    We can still use the boat by using the micro button on the bottom of the shifter to raid the out drive
    Just want it to work correctly
    Old 06-26-2016, 07:56 PM   #9
    My Model: Z276
    Send Brian Belcher:
    If the TRAILER button will still raise it, I'm fairly certain your troubles are the trim sensor. After you by pass it, you are perfectly fine not having the limiter. Just watch your TRIM GAUGE (if it still works) and don't hold it in the down position. Volvo`Penta doesn't even use one. Relys on the owner to know it's down or as high it's gonna get.
    Old 06-26-2016, 08:20 PM   #10
    My Engine: 5.7 v8
    Send Mwright:
    Ya trim gauge still works just fine I will try jumping them and get back to you thank you very much for your help
    Do you know what the engine L and trans L switches do?
    New Owner 1994 Mariah Talari z210 Perezmed Introductions 2 06-17-2014 02:34 AM
    New owner Mariah sx21 '03-'04 model donald Introductions 4 06-18-2013 12:46 AM
    New 1994 Mariah owner Harshlanguage Introductions 2 05-09-2011 01:22 AM
    1994 182 Barchetta Stereo Model? SEMIJim Original Mariah Talk 3 07-09-2009 12:08 AM
    New 1994 Mariah Davanti Z225 owner vkrishan Introductions 3 05-21-2008 12:39 PM
    There are 277 users
