Carbs are good for you
Old 06-25-2016, 02:06 AM   #11
My Model: Z276
Send Brian Belcher:
Default Re: Carbs are good for you
Shabah93, not be confused with Shabah280,AGAIN, did you go with the JR Marine gimbal repair? I'm doing that the middle of next month. If you are, let me know if there is room to double seal the gimbal pin. If not, could you mic out the OD and ID of the seal and maybe a picture of the area where the seal mounts. I will find a double lipped seal if there is enough room or may put two seals if there is enough of seating surface.
If I can double seal, I'll put EP grease in between the two seals for a better seal.
Old trick for fixing the leaking Dana60 front ends on our rockcrawlers.
    i think i did good KsZ190 Introductions 8 08-14-2012 02:52 PM
    NO Fuel to the Carbs mariah1stnow Mercury MerCruiser 11 06-27-2009 10:31 PM
    good deal or not so good? wssb11 Mariah Boats For Sale & Wanted 6 01-06-2009 01:00 AM
    Good job! sledge437 Introductions 0 07-17-2007 07:04 PM
    Total Members: 18,991
    Total Threads: 13,324
    There are 252 users
