Brand new boater here - need a pre-launch checklist
Just purchased my very first boat yesterday, '96 Talari. While I've driven friends boats here and there, I'm not familiar with Mariahs and with proper pre-launch and launch steps and was hoping folks on the forum here could help reduce the number of really stupid things I do as I'm learning - so yes there will be alot of very silly questions to follow:
Launching the boat: Is there a checklist that someone could point me to, ideally one that covers anything specific to my boat? (if anything) My understanding so far: Make sure outboard is trimmed up enough not to bottom out on anything. Check and re-check that drain plug is secure. Back the boat down the ramp until it starts to float a little, then release winch and safety chains and tie boat off away from the ramp, park car etc. Trim down outboard? What else am I missing? Starting the boat: Been reading how important it is to run the blower (bilge?) for a few minutes before starting the engine. I was a little alarmed that I had never noticed this being done in all the times I had been boating with friends with inboard or i/o boats. Big question here, alot of the labeling has been worn off the switches on my boat so I have no idea what 75% of them do. Which switch is for the blower? While fiddling with a couple the other day I did hit the one right next to the nav/anc switch that turns on my stern light pole - heard a loud whirring noise from the rear that sounded like it could be the blower. Next big question - how do I operate the choke before starting the engine? What other basic, obvious things am I missing? |
Re: Brand new boater here - need a pre-launch checklist
Pre-Launch Checklist
Make sure you have boat keys Remove cover Raise trim: Press trailer button on throttle handle until outdrive raised in traveling position Remove chocks from wheels Drag trailer to hitch (unlock tongue lock) Crank trailer down to ball Secure on hitch ball, lock tongue Attach chains Attach lights Attach brake cable Secure crank handle in horizontal position Check lights Double check hitch ball Look under seats for life preservers (1 for each person going to be in boat) Store trash bag, sun screen, towels & sunglasses Secure boat contents for travel Cover if necessary Check gas supply (Rule of thumb) 1/3 out, 1/3 back, 1/3 spare) Launching Check to make sure drain plug is in Remove 2 rear straps Install front & rear lines Install fenders Unhook 2 fasteners in front by hitch (leave winch hook attached until on ramp) Make sure trim is up Check fire extinguishers to make sure they’re full Make sure lanyard is on switch by shifter Disconnect trailer lights Turn on main power by: Raising rear hatch from 2 turnbuckles on either side of back seat. Turn red circular switch on starboard side switch to on. Lower rear hatch and fasten with turnbuckles. Turn on blower Back in water & submerge trailer to top of trailer fenders. Make sure someone on dock to secure front & rear lines Unhook boat from trailer Boat will float in water Push button in on throttle control on side. Make sure button is all the way in. Move throttle control all the way front & then half way back. Turn key until engine starts Bring engine up to 2,000 RPM |
Retrieving
Raise outdrive to full travel position (UP) Back trailer in water until top of trailer fenders Loosen both lines from dock Pass front line to person on trailer Hold back line to center boat on trailer Pull front line into center of trailer When boat is close enough attach strap to front bow eye Still holding rear line have trailer person crank boat into trailer Turn crank until bow eye is firmly under front roller Release rear line Pull boat from water Attach rear straps Attach front safety hook to bow eye Make sure center windshield pass through is closed Wipe down boat Secure contents in boat for travel Turn off main power by: Raising rear hatch from 2 turnbuckles on either side of back seat. Turn red circular switch on starboard side switch to off. Lower rear hatch and fasten with turnbuckles. Cover if necessary |
This is incredibly helpful. Thanks.
This is probably the most important one "Check and re-check that drain plug is secure." :yes_grin:
Forgetting the drain plug isn't just a newbie thing
I've been a boat owner for 5 years not a really long time but shouldn't forget something like this, but first outing this summer I forgot and pull away from the dock. Luck for me my Shabah still floats half full of water. |
| All times are GMT. The time now is 08:10 PM. |
