Top speed
Old 03-14-2016, 01:43 PM   #1
Stalbers is currently offline
My Model: Z202 shabah
My Engine: 5.7 mercuriser
Send Stalbers:
Default Top speed
What's the top speed of 5.7 1998 Mariah Z202. Just curious
  • Old 03-15-2016, 02:47 AM   #2
    Default Re: Top speed
    Lots of variables going on there. Weight of boat, elevation, prop your running, etc. I would guess mid to high 40s possibly lower 50. You can search on here under propellers or tops speed and may run across someone running your similar combo with a posted top speed.
    pllevine, Stalbers and Firestone like this.
    Thank you Motoxxx43 for this useful post!
    Stalbers (03-16-2016)
    Old 03-16-2016, 06:35 PM   #3
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    GPS verified, mostly empty my 98 z202 with a 5.0 could tickle 50mph, but could never get over it. Loaded down it was more like 46-47mph. I'm in WI at 700' above sea level.
    That was with a 21' prop. I had a 23' prop with it too, but that was too much prop and I couldn't get the rpm's all the way up.
    Thank you blockp for this useful post!
    Old 03-25-2016, 04:22 PM   #4
    baholtz is currently offline
    My Model: 202 Shabah
    My Engine: 305
    Send baholtz:
    Agree with BlockP.
    I've got a '98 202 with a 5.0. Running about 4,700 elevation my max speed is about 45-46 unloaded. That's running a hi-five 19, and not gps verified. Likely in the low 40's in all actuality. Loaded I'm lucky to get 40-44...
    I have noticed a difference at lower elevations, but mostly just in acceleration and not so much on top end.
    Old 03-25-2016, 06:55 PM   #5
    cptbraine31's Avatar
    cptbraine31 is currently offline
    My Model: 221 Talari
    My Engine: 5.7 Mercruiser
    Send cptbraine31:
    I have a 1998 Mariah Talari 221 with a carb Mercruiser 5.7 liter. With a 21 3-blade prop I am at about 52 mph and with my 15 4-blade prop I am at around 45.
    Turn your blower on 5 minutes before starting or while idle, if not, BOAT GO BOOM!!!
    Old 06-28-2016, 04:59 AM   #6
    pllevine's Avatar
    pllevine is currently offline
    My Engine: 5.0L Alpha
    Send pllevine:
    Not bragging, but this last Sunday I hit 59.7 MPH (GPS Verified) in Lake Monroe - Sanford FL with a '98 Mariah 202 5.0L and 19* prop.... Wouldn't have been such a white-knuckles if my depth finder wasn't reading out 6.4 feet of water.....
    Phil Levine
    1998 202 Shabah
    Old 06-28-2016, 12:06 PM   #7
    Hunter12345's Avatar
    Status: Silver Contributor
    Gallery Images: 2
    Send Hunter12345:
    Wow! Where u running with a 10 mph current lol!
    My 180, hit 64 once. Now, everytime i run it at wot 60 seems to be where i top out, somedays its 56 mph. 26* bravo 3.
    Thats quick for a 5.0 and 20' boat, hows the hole shot with a 19*?
    '98 shabah 180
    5.7l 350 mag
    Bravo III
    Old 06-28-2016, 06:33 PM   #8
    My Model: Z202
    Send Firestone:
    Well with my new smart tabs installed I just topped out at 47 MPH GPS with a 14.5" x 17 x 4 SS prop. Boat had an average load of 4 people and 1/2 tank of gas. With the old whale tail I could not get it over 44 MPH GPS. I am at about 4800' in elevation. I was thinking about getting a 14.5" x 19 x 4 as a back up prop for Lake Powell, but not sure that would give me the power I need for water sports. Thoughts?
    John
    Old 06-30-2016, 04:23 PM   #9
    jjt1276's Avatar
    jjt1276 is currently offline
    My Model: Shabah 202
    My Engine: 5.0L with Alpha 1
    Send jjt1276:
    Not sure what water sports you are doing, but I have a Shabah 202 with 5.0 and a 14.25x21 three blade. I also run smart tabs with 80lb piston on hole 1. I have no problems pulling single and double tubes. I can cruise around 15-20 while pulling. Getting an adult skier out of the water is doable, but may be difficult for a novice. Slower driving for say a wakeboard I have not tried. Hope this helps!
    Earl61 likes this.
    Old 06-30-2016, 04:27 PM   #10
    jjt1276's Avatar
    Send jjt1276:
    Just noticed that was you Firestone. Did you like/keep your tabs at hole 2? I like the way 1 performed better than 3 for me, but have not done any measured wot passes yet. I was lightly loaded and want to test with more realistic loading in the boat. Have a safe and fun fourth!
    Thank you jjt1276 for this useful post!
    pllevine (06-30-2016)
    220 Talari Top Speed LunenburgRider Original Mariah Talk 1 07-23-2013 02:37 AM
    Estimated top end speed??? suja415 Original Mariah Talk 25 05-04-2012 04:19 PM
    No Speed Lay Lake Mark Introductions 0 08-05-2010 12:47 AM
    top speed southcoastpower Original Mariah Talk 3 06-29-2010 09:30 AM
    speed and rpm jktbea Original Mariah Talk 7 05-20-2008 03:51 AM
    There are 277 users
