-   -   engine cuts out (http://www.mariahownersclub.com/forum/original-mariah-talk/10558-engine-cuts-out.html)
vern 06-21-2016 02:59 AM
Re: engine cuts out
Hello
The pick up is a long plastic tube. It did not appear to have any cracks or holes...
could it be something on the bottom of the tank that gets sucked to the tube, then
when the motor stops, it floats away?
Brian Belcher 06-21-2016 11:20 PM
Re: engine cuts out
Without a doubt, that's a possibility BUT, playing devils advocate, fuel level would not affect (effect?) that. Could fuel level just be a coincidence? Didn't you say that swerving would make it less severe ?
Dude, I wish u lived in central Arkansas. I'd come over and help you.
Do you have an engine oil, through the dip stick style pump ? I'd try to connect to the pick up unit with it still attached to the tank. Start pumping/ducking and see what comes out or better yet, if it stops sucking, which wouldn't suck.
Sorry
Paul F 06-25-2016 02:36 AM
Re: engine cuts out
Mine was stalling at 3000 rpm. Turned out to be a loose wire on the fuel pump circuit that stalls the engine if the oil pressure drops.
vern 06-25-2016 03:16 AM
Re: engine cuts out
i have a manual fuel pump..Do you?
Paul F 06-25-2016 04:07 AM
Re: engine cuts out
1995 4.3 2bbl
Sent from my XT901 using Tapatalk
vern 06-28-2016 02:07 AM
Re: engine cuts out
hello
where was this wire located?
Paul F 06-28-2016 03:31 PM
Re: engine cuts out
Don't know. My boat mechanic worked on it. I'm skittish about working on gasoline related items.
Brian Belcher 06-30-2016 01:12 AM
Re: engine cuts out
I wonder if he's talking about the anti diesel valve?
Brian Belcher 08-06-2017 01:25 AM
Re: engine cuts out
What ever became of this?
