-   -   Transom mounted courtesy lights (http://www.mariahownersclub.com/forum/original-mariah-talk/10472-transom-mounted-courtesy-lights.html)
dafucwuzat 09-06-2015 03:00 AM
Anyone have pics of these. I have 3 holes barely showing above rub rail dead center at transom. They are about 1/2" diameter. Wondering if it used to have the lights. Is that where they would have been mounted?
ShabahZ280 09-09-2015 08:33 PM
Re: Transom mounted courtesy lights
Can you post a pic so we can get a better understanding of what you're describing?
dafucwuzat 09-09-2015 08:49 PM
1 Attachment(s)
Attachment 6331If pic attached, I marked the 2 middle holes with blue tape. The are 2 more to either side of these about 6" away.
Motoxxx43 09-14-2015 03:19 PM
Was the rub rail ever replaced?
dafucwuzat 09-14-2015 03:23 PM
Not sure. Bought boat last year. These holes are bigger than a screw hole though. That's why I thought maybe this is where courtesy lights used to be, for wires to run through.
ShabahZ280 09-14-2015 06:33 PM
My guess is your rub rail was replaced at some point. Mariah never put courtesy lamps near the rub rail.
dafucwuzat 09-14-2015 06:38 PM
Ok thanks. I have seen that they had the courtesy lights but not sure where. Their add I saw was talking about lighting up the ladder at night etc so I wondered. Anyway, thanks guys
ShabahZ280 09-15-2015 08:12 PM
The only courtesy lights that were installed in the transom officially by Mariah were the engine lights mounted inside the engine bay, and the round transom light installed near the ski hook on the larger boats.
dafucwuzat 09-16-2015 12:32 AM
Ah ha. Didn't realize it was on big boats only.
frenner 10-07-2015 11:21 PM
Is it possible that someone had added a swim platform and then it was removed.
