-   -   Temperature gauge (http://www.mariahownersclub.com/forum/original-mariah-talk/10339-temperature-gauge.html)
Jerry Keane 07-12-2015 03:18 AM
Temperature gauge
Temp gauge will intermittently go up to 140 then drops and stay at 100. Will move off 100 some of the time when I back off the throttle. Sending unit and thermostat new? Any trouble shooting suggestions. Thanks
mariahshabah 07-16-2015 12:41 PM
Re: Temperature gauge
I had a similar issue where the temp would creep up when engine was at a low rpm. I had a mechanic replace the water pump for the stern drive water pickup which fixed the problem.
mikeyt 07-16-2015 02:40 PM
Replace the water impeller in the outdrive & have them flush the system while they're at it.
