bridge clearance?
Anybody know where I can find bridge clearance specs for Mariah boats? I've checked the Mariah website, but they have no info.
I'm really interested for specs for the following models: 1999 z212 2000 z252 2000 z250 2005 sc25 Thanks. |
By Bridge Clearance, you mean vertical clearance? I'd say stay away from bridges less than 6ft to the waterline. That should be more than enough on all those models.
Re: bridge clearance
Yes, I mean vertial clearance. There is a bridge that i have to go under, and the water level fluctuates depending on rainfall. At best there is 6ft clearance. At worst around 4ft. So I'm really looking for a boat that has a clearance similar to my 1999 z212.
One time I found a website that listed bridge clearances in the specification sections for their boats, but I forgot which site that was. Does anybody know of websits like this? |
FOUR FEET Yikes!!!:yikes: A 275 won't make it!
Sounds like at 4 feet you would need to trade it in for a canoe :)
The one bridge that we have in the nav channel near me I believe is 8 feet or probably around 3-4 when flooding in spring time.. heh. |
z212 makes it under
well the z212 will make it under the bridge, unless the water is real high from a lot of rain. I'd like to know how much taller a z250 is than the z212
So what your looking for is the freeboard dimension + the height to the highest point on the boat as in this picture:
The freeboard dimension you should be able to find as a listed dimension. The other portion though will probably not be listed. Enlisting someone to measure that for you seems to be the only method. Those of you out there with these models willing to measure for us and post up the dimensions? |
any more bridge clearance numbers
Anybody got any real world numbers for bridge clearances?
| All times are GMT. The time now is 01:02 PM. |
