1996 Z210 Gas Gauge Won't Work
Old 06-08-2015, 01:18 PM   #1
BSP Thread Starter
BSP is currently offline
My Model: Z210 Shabah
My Engine: 5.7L Alpha One
Send BSP:
Default 1996 Z210 Gas Gauge Won't Work
Hey Guys! I'm the new proud owner of a 1996 Z210 Shabah. Just put in in the water this past weekend for the first time and couldn't be happier. The only issue is that the gas gauge does not work. The needle does not move at all. It stays below the "E". I don't see any access to the sender anywhere, and the wiring at the gauge all looks good. How do I access the sender? Any suggestions? Thanks in advance for your help!
  • Old 06-08-2015, 08:07 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 1996 Z210 Gas Gauge Won't Work
    First try shorting the sender terminal on the back of gage to ground, to determine if the gage is good. If the gage is good it should read full with the terminal shorted.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-09-2015, 02:16 AM   #3
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Originally Posted by BSP View Post
    ..... How do I access the sender? Any suggestions? Thanks in advance for your help!
    Tip the back seat forward and you should see 2 aluminum strips screwed down to the floor going forward from the motor side enclosures. Take these off and then the center floor piece will hinge forward. This exposes the aft end of the tank where your sending unit is located as well as your fill and vent hose attachments to the tank.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 06-09-2015, 11:37 AM   #4
    BSP Thread Starter
    Send BSP:
    Great. Thanks for the help guys! I'll have a look at both now that I know what to look for. Thanks again!
    1996 z210 atlanta ga jsewall82 Mariah Boats For Sale & Wanted 0 10-04-2014 01:22 PM
    1996 z210 for sale ual777mech Mariah Boats For Sale & Wanted 1 10-01-2014 01:31 PM
    1996 z210 Convertible Top jsewall82 Original Mariah Talk 2 05-16-2013 06:07 PM
    1996 Z210 LE to sell. Cupcakes58 Mariah Boats For Sale & Wanted 10 04-28-2013 05:05 AM
    1996 z210 jsewall82 Original Mariah Talk 7 04-18-2013 03:10 PM
    There are 461 users
