Wheel bearing kit for 1997 Chariot trailer
Old 05-22-2015, 02:55 PM   #1
higginslakejoe is currently offline
My Model: Z209 Talari
My Engine: 5.7L Bravo
Send higginslakejoe:
Default Wheel bearing kit for 1997 Chariot trailer
I am looking for where I can buy a wheel bearing kit? Any leads are much appreciated.
  • Old 05-23-2015, 04:49 PM   #2
    Default Re: Wheel bearing kit for 1997 Chariot trailer
    There really is not a whole lot too special to trailer hubs. If you were to take the ones you have to a place like NAPA, Autozone, etc you should be able to find what you are looking for. I have even purchased a bearing kit from Walmart in the boating/RV section. They are that common.
    HERE is a link to eTrailer. They have a ton of parts. That link takes you to the #3500 axle bearing which Im assuming you have. If you pull your bearings you should be able to get a number off of them.
    BTW... Welcome to MOC.
    Thank you Motoxxx43 for this useful post!
    higginslakejoe (05-29-2015)
    Old 05-29-2015, 07:26 PM   #3
    Thanks! Had my Mariah since 99. Love it!
    Old 09-03-2015, 05:47 AM   #4
    impact1839 is currently offline
    My Model: z244 Jubilee
    Send impact1839:
    I have a 1997 Jubilee and chariot trailer. Just replaced all the bearings and one was non standard.
    UFP provided the actuators, axles, and bearings for these trailers for some time. Go to their website and look up the catalog UFP - Axles
    The 1997 Chariot has the following:
    L68149 outer bearing
    L68110 outer race
    L44649 inner bearing
    L44610 inner race (Hard to find in sets)
    Seal 2.33 outer diameter and 1.68 inner diameter (Hard to find)
    Bearings & Races
    The (OEM) manufacturer makes the bearing and risers in a kit for a steal and at 1/3 of buying individually. You can purchase at very attractive pricing the kit from california trailer works https://caltrailerworks.com/online/p...&cat=13&page=1
    Many places sell sets but all the sets will have everything you need but the correct size inner race and seal if offered. THe L44611 inner race will be offered instead of the L44610. The former is used on utility trailers wheras the latter is used for marine trailers, Nevertheless you will still come off cheaper by buying the set and purchasing the inner race and seal separately.
    Hopefully you either have the foresight to purchase before you need these items but like many we get it when we need it and we pay dearly for needing it now. Think ahead and order them now you will save 2/3 by doing so which is significant. I paid $45 for the five items separately and later purchased the set mentioned above + separately purchased the inner race and seal for$32. I then ordered from California trailers $19 set+ shipping. May be cheaper to buy the set + riser and seal locally if you have that option unless you want OEM or you are ordering at least two sets.
    Seal
    The seal is here https://caltrailerworks.com/online/p...cat=150&page=1 and it is 2.33 OD which is hard to find.
    Mariah used a good company for trailer parts and we have them all available to us via the link above. Actuators and all their parts, hubs, drums, bearings, seals, axles, brake assembly and parts all from the place they got them from to start with which is nice to know.
    I had a tuff time in this process but now I got it down. Hope the info helps
    mikeyt likes this.
    Thank you impact1839 for this useful post!
    62 driver (02-29-2016)
    Old 09-03-2015, 07:46 PM   #5
    L68110 outer race
    Bearings & Races
    Seal
    Thank you! I have had great difficulty finding the inner seal.
    Joe
    Old 08-17-2020, 02:36 PM   #6
    birddognva is currently offline
    My Model: 211 Talari SE
    My Engine: 5.7
    Send birddognva:
    Seal available here:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    (Pack of 2) WPS Trailer Hub Wheel Grease Seal 168233TB 1.688'' x 2.332'' Double Lip #84 Spindle
    Bearing Kit here:
    Dutton-Lainson 21866 6508 Trailer Wheel Bearing Set
    Includes 2 bearings with races, 1 grease seal and cotter pin
    1-3/8 x 1-1/16 inch spindle O.D.
    1.98 outer hub I.D.
    Cone nbr L44649/L68149
    Cup nbr L44610/L68110
    Chariot Trailer Z210Shabah Original Mariah Talk 3 08-07-2020 10:56 PM
    chariot trailer rebuild Dave Z252 Trailering and Tow Vehicles 1 04-04-2015 04:24 AM
    Weight of a Chariot trailer jchemotti Original Mariah Talk 3 08-25-2010 12:25 AM
    There are 502 users
