Gas
Old 04-24-2008, 01:15 AM   #11
Mariah Z276's Avatar
Mariah Z276 is currently offline
My Model: 1997 Z276 7.4L Bravo III
Send Mariah Z276:
$3.37 a gal. for regular, and now you say I should move up a grade because of ethanol. It already takes $400.00 to fill up.
Butch Eigenbrod
1997 Z276 7.4L Brovo III
Cape Girardeau MO.
  • Old 04-24-2008, 02:11 AM   #12
    KSP181's Avatar
    KSP181 is currently offline
    My Model: 1994 Barchetta 182, 4.3L alpha 1
    Send KSP181:
    I'm sure that I am not the smartest person on this board. With that said...My understanding is that octane is the resistance for predetonation. The higher the compression of your engine the higher octane you need to prevent predetonation. If your engine does not need a high octane to prevent predetonation (87) and you put high octane in it, then you will see no advantage.
    People sometime confuse high octane with high performance. If your engine is built with high compression then high octane is needed and you will see a loss when using low octane fuel (predetonation). If your engine is build for low octane (low compression) you will see no improvement when useing high octane.
    There are several websites that discuss octane ratings if you need to find out what fuel to run to get the most out of your boat without wasting money.
    1994 Barchetta 182 - 4.3L
    Vic
    Old 04-24-2008, 05:53 AM   #13
    Hi KSP181
    I don’t think anyone here can claim their the smartest, that’s for sure… that said, you’re absolutely correct about the pre-detonation and if anyone is interested in learning more about Octane they can click here:
    octane rating.
    There is one situation where higher octane can improve your performance - at times when the engine is under extreme loads such as a boat very heavily loaded with people and gear and expected to run flat out. The higher octane would suppress pre-ignition allowing a higher top speed because the operator would not have to back the RPMs off as soon due to engine pinging. This is the same for a tow vehicle when pulling a grade
    There’s a little know secret - there are vehicles designed to run on 87 octane, but when higher octane is used, the computer recalibrates the fuel injector duty cycles and engine timing to take advantage of the higher octane (or lack of ping). One such example is the Ford Triton series. Though the gains are small (I have heard up to 6%), it can make a difference while towing and acceleration. I have tried it out myself after hearing of this back in 97 and later on our 99 with a re-programmer for the engine computer.
    Hey Mariah Z276, if the octane you’re using does not ping when you’re out and about, then you’re OK, but if you’ve got the knock, it’s up the grade of gas or look at getting another motor some time in the near furture. What’s an extra $5 to $10 bucks compared to another motor, right?
    Believe me when I say I totally sympathize with everyone with larger V8 motors. For the last 24 years, I ran a 3.0L and now I have a 7.4L. So you can imagine what I'm having to get used to at the gas pump. What makes it worse is, many stations here limit the dollar amount per fill up to $50.00. That won't even fill the Expedition's tank let alone put a dent in the Talari's...OUCH, but I figure that's the price I have to pay for that extra gettiyup and go!
    Sorry, just my $0.02, make that $0.04 worth of ranting,
    Old 04-24-2008, 07:15 AM   #14
    moondance100's Avatar
    moondance100 is currently offline
    My Model: 1995 Z240 Talari 502 Bravo III
    Send moondance100:
    $3.37 for regular? What a bargain! Everyplace I'm seeing is $3.60-$3.65!!! I only burn about 5-10 gallons per week. If someone wants to ski or kneeboard, they better bring a $50 bill with them!
    Doug
    95 Z240 Talari, 502, Bravo 3
    Old 04-24-2008, 07:11 PM   #15
    Send Mariah Z276:
    Thats good news. I don't have any pinging. It was mentioned earlier in the thread that with ethanol you need to up the octane. Thanks to you and KSP181 for the explanation.
    Butch Eigenbrod
    Cape Girardeau MO.
    Old 04-24-2008, 07:19 PM   #16
    Z 202's Avatar
    Z 202 is currently offline
    My Model: Mariah Shabah 202
    My Engine: 5.7L Alpha 1
    Send Z 202:
    Around here most gas stations dump all the ethanol in during the winter, which kills your winter mileage. So it's less likely to be an issue during the boating season.
    As stated in the Mercruiser link WetWilly provided, the merc design should handle 87 octane with up to 10% ethanol, and as noted, the only reason to go higer is if you are experiencing detonation when under load.
    My Mariah
    Old 04-24-2008, 07:57 PM   #17
    180diablo's Avatar
    My Model: 1993 Diablo 180
    Gallery Images: 30
    Send 180diablo:
    There is a lot of good information about fuel in this thread!
    I think im going to give my 3.0 a hug when I get up to the cottage.
    lol.
    ~ Ryan
    Owner of the 3.0L Powerhouse!
    Old 04-24-2008, 11:28 PM   #18
    lol.
    Uh, I think there may be a law against getting intimate with your sterndrive....
    Old 04-25-2008, 02:40 PM   #19
    180diablo's Avatar
    Gallery Images: 30
    Send 180diablo:
    Ummm no .. only in Alabama there is
    ~ Ryan
    Old 04-25-2008, 02:47 PM   #20
    Z275's Avatar
    Z275 is currently offline
    Gallery Images: 15
    Send Z275:
    As I've said before the most important thing is to stay away from gas with Ethanol in it! At most marinas this won't be a problem but a lot of us fill up at gas stations before getting to the water. This is where you have to be careful. Most mix 10% ethanol with their gas now.
    Jason
    2001 Mariah Z275 - 405hp 7.4GSi
    There are 283 users
