Bilge question. 268mcc where is the water?
Old 05-15-2015, 03:20 PM   #1
donly1's Avatar
donly1 is currently offline
My Model: 268 MCC
My Engine: 5.7 350 MAG EFI Bravo3
Gallery Images: 13
Send donly1:
Default Bilge question. 268mcc where is the water?
Bilge question. 268mcc where is the water coming from?? the bilge pump emptied everything and then I pulled the plug drained it, and noticed a ton of water coming from the plug and one of the holes on the starboard side where there are three holes. one hole for interior sink, the other for shower pump, and third I have not idea.... Any ideas????
2001 Mariah 268MCC 5.7EFI Bravo3
  • Old 05-15-2015, 03:31 PM   #2
    Default Re: Bilge question. 268mcc where is the water?
    I'm not 100% certain on the Z268, but on my Z280, there's a midship bilge pump under the step going down into the cabin. This should pump out the starboard side with the sink and shower outlets. This pump is in wired in with the main engine bilge pump switch on the dashboard. My guess is your midship bilge may not be working correctly, or the automatic float may need to be cleaned.
    Old 05-16-2015, 04:08 PM   #3
    donly1's Avatar
    My Model: 268 MCC
    Gallery Images: 13
    Send donly1:
    Great thanks for the info, I had no idea that both bilge pumps activated at the same time....
    Bilge pump rewire question rhinoz Original Mariah Talk 6 05-30-2013 01:30 PM
    4.3L Oil in the Bilge but no water in oil dwymer64 Mercury MerCruiser 7 06-09-2011 12:54 AM
    Z275 Bilge Blower question csterner Mercury MerCruiser 8 04-14-2011 01:46 AM
    Bilge pump question nglauer Original Mariah Talk 7 07-27-2010 01:44 AM
    Water in bilge .. good or bad? 180diablo Original Mariah Talk 6 10-07-2007 05:44 AM
    There are 310 users
