Westland Cover from RNR not fitting ?
Old 05-04-2015, 04:41 PM   #11
My Model: 180 Diablo
My Engine: 3.0 Mercruiser
Send TN_Diablo:
Default Re: Westland Cover from RNR not fitting ?
My boat has two swivel bucket seats with a large bench and sundeck in the back. It's white and beige with beige carpet and the graphic similar to yours but multicolor down the side. I don't have any good pics with me right now. When I told my wife I really wanted to get a boat she was against it until we looked at and rode in this Mariah.
We got ours when our kids were about 4 and 6. We spent many afternoons at the lake pulling tubes or knee boards and even learning to ski with the kids but the thing they like the most was to bring friends along and take turns riding 2 or even three tubes. Throwing animal crackers at the tube riders to see if they could catch them comes to mind too.
Our boat came with a 19" 3 blade, 2:1 Alpha drive and 3.0 motor. Not super powerful but has always been enough for what we do and WOT is too much for riders. I used to sling and bounce tube riders back and forth with precision, making it fun but keeping it safe.
We (I) ruined the original prop on a rock ledge late one summer and over that winter I found some incredible deals and picked up both a 19 and a 21 from a couple places for under $50 each. If it is just my wife and I going out cruising I run the 21 and I love it. Cruises much better at a little lower RPM. If we might have a load (friends and tubes) I switch to the 19.
I've been reading about smart tabs and thinking I might give these a try as it sounds like it would make the boat even better. Did you ever try them? My bow rise is a bit high getting on plane and it bounces at times when I trim up to cruise but never knew I needed them until I started reading. Might be one more thing to sort out this summer.
  • Old 05-04-2015, 07:52 PM   #12
    nglauer's Avatar
    nglauer is currently offline
    My Engine: 3.0L Alpha one
    Send nglauer:
    I HIGHLY suggest the smart tabs... unbelievable difference. Before I purchased them I swapped over to a 17p prop to jump it out of the water. After the smart tabs, I didn't need the 17p. You won't believe the difference it makes, it was by far the best investment. My boat at low speeds through wake areas wouldn't go straight to save it's life.. i'd have to crank the wheel back and forth because of the slow speed prop wash. Once I put the tabs on.. it operated like it was on rails. It was straight as an arrow at idle speeds, and I could turn the boat faster than any sane person should at top speeds. The holeshot was night and day as well, it puts the boat on plane faster than any product i've seen - I know it works better than "whale tails" because a friend of mine had a sister boat to mine, but with an expensive hydrofoil. You can adjust them in the water as well, and all the parts are easily replaced if something were to break. However, they seem really durable unless someone tries to use them as a step lol. I've seen people claim that they lost a few mph with them, but I used a GPS speedometer on my phone and saw about a 1-2 increase. Besides the tab, adding the lowrance depth unit was the next best thing. I secured the through hull transducer in the engine compartment with a wax toilet ring - so it didn't require any cutting or glue. I did run a small probe out the rear of the boat for the water temp though, as the unit told temp and depth, and had a depth alarm which was nice for the area's we boated.
    You'll have to post some pictures sometime. I'd love another Diablo. I think one with the 4.3L would be really nice, although my 3.0L was great on gas, and had plenty of pep.
    Buy those tabs! I promise, I don't work for them.. and make 0 commission lol. They were just that amazing.
    Nick
    Nick
    SOLD 8/5/2013 -2001 Mariah Diablo 180 3.0L Alpha 1
    -2007 GMC Canyon 4x4 Crew Cab
    -2010 GMC Acadia SLT
    -1993 Camaro "SCCA Project Car"
    Old 05-04-2015, 08:36 PM   #13
    Send TN_Diablo:
    I've made up my mind I'm ordering the Smart Tabs. Mine also wanders aimlessly at low speed. Did you mount yours outboard as possible keeping flush to the flat and ignoring the chine or letting the chine basically go deeper than the tab? From what I measured there is hardly a flat spot on the bottom as wide as the tab. 7" might be the widest flat I find. I should take a picture but I'm sure we have (had) the same hull.
    I still use my now antique, temperamental, handheld Garmin GPS for the boat. When it works it shows my speedometer is close. Top speed on my boat is only just over 40 IIRC. I keep trying to find a hill to see if it will go a bit faster.
    I have a depth finder but it's a basic one that shoots through the hull mounted in that thin spot under the motor. Nothing fancy but has a depth alarm. Problem with our lakes in TN is there are basically underwater cliffs. Might be 50+ feet deep then 2 feet away it's 2' deep, and that's all rock.
    Old 05-04-2015, 08:53 PM   #14
    nglauer's Avatar
    Send nglauer:
    Here are some additional pictures of mine. I had the SX tabs (although I can't remember which struts mine had). However, they are really nice and if you call they will suggest which size struts. They are also adjustable, so you can dial them up or down some manually. Mounting was very easy, mark/measure three times - drill once lol. I believe I used 3M 5200 caulking/adhesive to deal mine too. I think installation took 15 minutes after digging all of the tools out. I did have to cut the center bunks on my trailer, because the tabs were catching on them. I think I cut about an inch off each side and rolled the carpet back down. As for the exact measurements - I just based mine off of some of the pictures here on the site. However where I finally put them made a HUGE difference. Plus... I found mine in the Cabela's bargain cave for around $45.00 bucks with cut packaging, but never used/installed... which made it an even better deal at the time
    Keep me posted when you get them! Trust me - it'll be like a different boat. It even felt like it handled choppy water better as well. The Ohio river wasn't as drastic change wise.. but there were a couple of places that we went to that were sketchy like that. I found that the lowrance was helpful when just floating down river off the shore line. Sometimes I'd just sit about 1/3 of the way off the shore line, and just let the current drag us down river - however the closer to the shore the crazier the depth changes are, so the lowrance kept us off random sandbars lol.
    Good luck!
    Nick
    Nick
    Old 05-04-2015, 10:34 PM   #15
    Send TN_Diablo:
    Your tabs are mounted where I imagine I need to mount them. My trailer bunks are almost flush to the end of the hull, maybe the hull hangs over <1". It might be wise to trim them as you did.
    Now if I can find a great deal like you did. Like others it kinda bothers me to drill into my hull but in reality fiberglass and gel coat repair is really pretty easy even if you made a mistake but I also subscribe to the consider all your options, measure many times, then drill or cut once.
    I looked at the website and was thinking white would be better on the bright white hull but black matches the motor and looks fine.
    Thanks again for all the time and pictures to let me get perspective on things.
    Old 05-11-2015, 03:49 PM   #16
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    People will tell you to mount them as wide as possible, but don't worry.
    Apart from the fact that you just can't mount them any wider on a Mariah, they work very well just where Nick has them. Me also on my 180 Diablo
    If you have them any wider then they will be out of the water and what's the point of that???
    Here's a short video I made a couple of years ago of my Smart tab's "earning their keep"
    It was made with my old GoPro, Must get around to making one with the New One.....
    nglauer likes this.
    Thank you Andy b for this useful post!
    nglauer (05-11-2015)
    Old 05-11-2015, 07:12 PM   #17
    nglauer's Avatar
    Send nglauer:
    Somehow i missed this video. Thats pretty awesome Andy! Love to see another one with the camera pointed toward the transom from behind.. perhaps on a pole. I thought the tabs were the best investment i had made while owning the boat.
    Nick
    Old 05-26-2015, 09:02 PM   #18
    Send TN_Diablo:
    Default Re: Westland Cover from RNR not fitting- UPDATE
    As a follow up to the new cover I did something I am very happy with. Since the new cover came with a lot of long straps I used some of the webbing and clips to make straps that attach to the windshield snaps and cleats to locate my support poles. My poles are simply aluminum tube from home center I made with white rubber chair tips for < $20. The heavy duty snaps and tool came from sewing center for < $15 and I still have extras. Their are snaps on top of each pole and some heavy needle felt I had to cushion the top of each pole. The rear I even added a piece of plastic about 4x6 to distribut the load a little.
    It takes all of about 1 minutes to strap these in. I can unclick just the rear strap near the tow cleat so that I can open the sundeck to access the motor without disturbing anything else.
    I plan to update my bungee cords that hold the cover tight but it's fitting quite nicely now.
    I rained yesterday and except a couple tiny spots near the darts in the cover water did not pool at all.
    I know we should have been on the lake with the holiday but we never head to the lake on these busy weekends. I much prefer an afternoon off midweek when we usually have nearly the entire lake to ourselves and can cruise or just relax until about sunset.
    Next up Smartabs which have been ordered and expect to see any day if not today.
    Andy b likes this.
    Old 05-31-2015, 01:20 PM   #19
    Send TN_Diablo:
    I was hard to bring myself to drill holes below the water line but I did. I dry fit everything first then filled the holes with 3M 5200 sealant. The hardest part was probably squeezing that small tube of expensive polyurethane to fill the holes. I looked for 4200 in a caulk tube which would have made it easier and should have ordered that but the 5200 was available locally.
    3/8" Thru Hull Fitting bigzoon Original Mariah Talk 10 05-05-2017 03:34 AM
    Drive Oil Fitting in Transom ?????? 99 Mariah 258 Mercury MerCruiser 2 08-19-2014 07:01 PM
    Fitting Smart Tabs to a new SX18 bakdraft Projects 6 07-06-2010 03:04 PM
    Fitting a SE 300 sport hydrofoil Mayal Mercury MerCruiser 10 02-28-2008 04:23 PM
    Total Threads: 13,324
    There are 342 users
