Anyone shortened their bimini??
Old 04-13-2015, 04:07 AM   #1
gahooligan's Avatar
My Model: 202
My Engine: 5.7l
Send gahooligan:
Default Anyone shortened their bimini??
Just wondering if anyone has cut down their bikini poles and re crimped them? I am looking at a tower and don't want to spend more money for a new bimini seeing as I bought ours two years ago... I'm sure it can be done, just wondering if anyone has some pointers or suggestions! Thanks y'all!
  • Old 04-24-2015, 03:59 PM   #2
    Txtruckerpaul's Avatar
    Status: Gold Contributor
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    Default Re: Anyone shortened their bimini??
    Trimmed mine down about a foot last year. I got a universal bimini and installed it. Looked like it was made for someone that was 8 feet tall. It looked rediculous, so i trimmed it down. My poles are aluminum so i used a small tubing cutter. Instead of trying to recrimp the fittings to the poles, i drilled a hole on each side and put a couple of pop rivets in. The shorten the pole length, i cut the main poles and installed the top. With a helper holding it straight, i measured the distance from the mount point to the top where the other poles would attach, then cut them. It wasn't hard to do. Now my top is about 6 foot up from the floor and looks a lot better!ImageUploadedByTapatalk1429891140.091236.jpg
    Thank you Txtruckerpaul for this useful post!
    Lvano (05-30-2017)
    Old 04-24-2015, 04:48 PM   #3
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Thanks for the reply! I was sure it could be done. Thanks again for the input! That's a nice looking boat!
    Old 04-24-2015, 04:56 PM   #4
    Send Txtruckerpaul:
    Welcome and thanks! Its not hard to do, just kinda cumbersome. Only problem I've had is with the stainless brackets that mount on top of the windshield frame. They will rub through a boat cover in no time. Bought a new cover last week and took it to my upholstery shop where they sewed in some real heavy reinforcements. I situated the bimini top to where i could lay it down flat against the sun deck for storage with the cover on. Worked out real good
    Old 04-24-2015, 05:16 PM   #5
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    Mine is mounted outside the windshield. Im installing a tower next week and may need to shorten the bimini.
    Bimini Top Mhilly Original Mariah Talk 3 04-06-2016 03:51 AM
    I need a BIMINI top, any out there? midwest mariah Original Mariah Talk 11 03-30-2015 10:22 AM
    Wanted: Bimini Top Help spinks99 Mariah Parts For Sale & Wanted 15 01-10-2012 05:29 PM
    bimini top Chris182 Original Mariah Talk 4 06-27-2011 01:52 PM
    Bimini Top Colin Logie Original Mariah Talk 2 06-16-2009 12:43 PM
    Total Members: 18,527
    Total Threads: 12,959
    There are 150 users
