Need some help
Sea Fox - Mariah Talk
Old 07-05-2010, 10:20 PM   #1
CARL SWINDLE is currently offline
My Year: 2007
My Model: FS18
My Engine: 3.0
Send CARL SWINDLE:
Default Need some help
Hello, I have a 2007 FS18 I would like to install led lights, I already have a powered Acc. swith in my dash, but what is the coorrect way to connect my wires. Currently I have a black wire that is connected to all of my switchs and a red wire. Where and how do I connect my lights.
On the back of my Acc. switch I have three terminals
  • Old 07-15-2010, 01:53 PM   #2
    recelect is currently offline
    Send recelect:
    Default Re: Need some help
    So the black wire going to all your switches (should) be the "ground wire". No need to worry about that one. The red wire should be your power source coming from the fuse block. The third terminal (bottom if your switches are like mine) will go to the power side of your LEDS. Then the other wire coming from your LEDs needs to go to ground.
    If they don't come on, first check to see if the light on the switch is coming on: if it is, the most likely you either have a bad ground to your leds, or you have the leds wired backwards, so simply switch the 2 wires.
    If the light on the switch does not come on, Then check your fuse panel. Make sure 1. there is a fuse, 2. it is not blown, 3. it is not corroded.
    Hope this helps!
    Old 07-15-2010, 04:34 PM   #3
    My Year: 2007
    My Model: FS18
    My Engine: 3.0
    Send CARL SWINDLE:
    Thanks for the info, all lights are now working
    Total Members: 18,994
    Total Threads: 13,326
    There are 392 users
