Mercruiser V6 with full throttle only 4000 RPM
Sea Fox - Mariah Talk
Old 05-25-2010, 08:31 PM   #1
Klaas Kos is currently offline
My Year: 2004
My Model: sx18
My Engine: 4.3 alpha one sterndri
Send Klaas Kos:
Default Mercruiser V6 with full throttle only 4000 RPM
Hello all,
I have a SX18 from 2001 with a mercruise V6 4.3 190 hp. I have installed a 19P x 14 1/8 4 blade stainless steel propellor.
I only get 4000 RPM with full throttle and max speed is 42 mph. When the engine is in neutral i get easy 5000 RPM and maybe more with full throttle.
Does anyone has a sugggestion what the problem can be that i cannot reach the normal 4800 RPM and max speed from at least 45 mph.
With the original prop. 3 blade alu. 23P x 14 5/8 i had the same problem.
The engine runs very smooth and has enough torque.
  • Old 05-25-2010, 09:24 PM   #2
    Default Re: Mercruiser V6 with full throttle only 4000 RPM
    Here's a list of possible causes...most of these you can eliminate pretty quickly.
    Engine Won't Reach Operating RPM. Check
    Fuel condition. Type and Octane possibly old fuel
    Propeller pitch or diameter, damaged blades
    Restricted fuel pickup tube or anti siphon valve Fuel System Test
    Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
    Marine growth on hull and outdrive
    Wrong gear ratio in outdrive
    Restricted carburetor air intake (clogged flame arrestor)
    Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
    Poor cylinder compression Compression Test
    Carburetor defective, or wrong type.
    Fuel pump pressure and vacuum
    Boat overloaded, improperly loaded, or improperly trimmed.
    Engine Overheating
    Engine timing and ignition system operation
    Remote control cables and linkage for proper travel to open throttle plates fully.
    Klaas Kos (05-26-2010)
    4.3 L misses at 4000 rpm nooner Introductions 0 05-15-2010 01:18 AM
    Wanted: Full cover for '01 202 Shabah gjaxon Mariah Parts For Sale & Wanted 2 06-09-2009 03:17 PM
    Full canvas bimini top Segmenta Sea Fox - Mariah Talk 1 08-09-2008 11:00 AM
    engine acting wierd at full throttle MariahMX20 Mercury MerCruiser 8 07-16-2008 12:10 PM
    Battery box full of water dudders General Maintenance 5 08-28-2007 12:35 PM
    Total Members: 18,994
    Total Threads: 13,326
    There are 348 users
