1998 204 jubilee what is the stock gear ratio on the out drive
Old 09-30-2014, 11:05 PM   #1
Firecop119 is currently offline
My Model: 204 Jubilee
My Engine: 4.3 merc
Send Firecop119:
Default 1998 204 jubilee what is the stock gear ratio on the out drive
Hello all. I just bought a 1998 204 jubilee that can't get its butt out of the water. I have changed props with no help. I finally took it to the local marine and he did some home work on it and he says it has a v8 out drive and I have a 6. He also called merc and gave them all the id numbers and they said that boat was order with the package v6 and a v8 out drive which screws up the gear ratio. Why would anyone do this or is my marina taking me for a ride. If I put more than 3 people in the boat it won't get over 10mph. Please help clear this up. If u want to call and talk that would be great. Pm me for my number. Thanks everyone
  • Old 10-01-2014, 02:22 AM   #2
    Default Re: 1998 204 jubilee what is the stock gear ratio on the out drive
    You haven't mentioned the most important pieces of info. 4.3? Alpha outdrive? EFI / Carbed? What's the gear ratio on the existing outdrive?
    If its a 4.3 & Alpha outdrive it usually came with a 1.62, 1.65 or 1.81
    Old 10-01-2014, 09:46 AM   #3
    My Engine: 4.3 merc
    Send Firecop119:
    Oops I'm sorry. It's carbed And I think he said it has a 181 in it now which is geared for a v8 the v6 should have the 162. I might have that backwards and its a alpha one
    Old 10-01-2014, 12:45 PM   #4
    If its carbed then the 1.62 or 1.65 was the correct ratio. If its an Alpha drive then that's the correct outdrive for it. The Alpha 1.81 ratio was used for the some of the earlier 4.3L engines (with lower hp ratings) along with some of the newer ones used in the Sea-Fox versions (less weight than the original Mariahs) but not used in a V8. V8 engines usually came with 1.65 down to 1.47 ratio outdrives. Bravo 3 outdrives were the exception to this. You might want to find another "mechanic".
    Old 10-05-2014, 08:07 PM   #5
    My Engine: 4.3 merc
    Send Firecop119:
    sorry it took so long to get back with ya. it has a 1.81 on it right now and the mechanic says that's to much for it. he is a very reputable mechanic.he was recommended by some charter boat captains I know. with that gear ratio woud it be hard to get that boat moving with weight in it and if not what ratio would be good and what would a good average price be for all the repair. sorry for all the questions but I really appreciate the help
    Old 10-06-2014, 07:40 PM   #6
    ipgregory's Avatar
    ipgregory is currently offline
    My Model: Z308
    My Engine: Twin 5.0L EFi/Alpha 1s
    Send ipgregory:
    My 04 SC21 has a 4.3carb and a 1.81 Alpha 1.
    Ian
    2000 Z308 MCC, twin 5.0L
    2004 SC21, 4.3L (Sold)
    Old 10-08-2014, 02:21 AM   #7
    My Engine: 4.3 merc
    Send Firecop119:
    ok I goofed. it has a 1.62 not a 1.81 plus the mechanic today told me that it has the original plugs wire and cap and had a miss so im having him change them out
    Old 10-08-2014, 03:27 AM   #8
    You goofed? Didn't your 'mechanic' tell you it had a 1.82 and the gear ratio was 'all wrong' for that motor? Or did u just misunderstand him....
    And how the hell would your 'mechanic' know that the engine has the original plugs?
    Old 10-08-2014, 05:22 AM   #9
    My Engine: 4.3 merc
    Send Firecop119:
    I'm the one that misunderstood him. I had it backwards. And I'm just going by what he said on the plugs. He said it started to jump spark and miss when the engine was under load
    Gear Ratio Alpha One Gen II LunenburgRider Original Mariah Talk 7 06-26-2013 02:05 AM
    Change prop or gear ratio paulcj77 Prop Talk 4 11-26-2012 04:58 PM
    mariah 182 shabah incorect gear ratio? roadrash Prop Talk 5 07-02-2012 10:49 PM
    1998 Mariaha Z222-not stock snowboy Mariah Boats For Sale & Wanted 0 05-09-2012 03:11 PM
    How do I find my gear ratio?? Medic574 Mercury MerCruiser 8 05-11-2010 06:14 AM
    There are 361 users
