5.7 liter in 2000 mariah
Old 05-29-2014, 04:25 AM   #1
samimarkie is currently offline
Status: In Limbo
My Model: MARIAH 24' DECK BOAT
My Engine: 5.7L INBOARD
Send samimarkie:
Default 5.7 liter in 2000 mariah
I am planning on updating the engine to a 4bbl intake and carb. I've run into a slight issue. Does anyone know what the small approx 1/2" x 8" copper pipe in the attached pictures (from the intake to the exhaust manifold covered in a sock material) is used for? Can I eliminate it when I change to a 4bbl carb abd intake? any issues to be aware of when upgrading to the larger carb? Any thoughts on what carb to use? what did they come with? I'm a good car guy and a little skidish with boats. Don't want to screw it up. Any advice would certainly be appreciated. Thank you
  • Old 05-29-2014, 05:14 AM   #2
    Default Re: 5.7 liter in 2000 mariah
    It almost looks like some sort of heat riser for a choke setup , but I don't think that is it. Does the carb have a electric choke on it?
    I'll try and search into it further tomorrow.
    Old 05-29-2014, 11:02 AM   #3
    Status: In Limbo
    Send samimarkie:
    It does have an elctrical choke. I thought it may be a heater but I think there is an exhaust passage that runs under the carb (similar to automotive) for that. Might it be for cooling the underneath of the carb so there is no vapor lock due to heat?
    Old 05-29-2014, 11:52 AM   #4
    sami , can you get me the ID number from the drive or engine?
    That might help pinpoint things a bit.
    You got me interested in this too , never seen it before.
    It doesn't have a closed cooling system does it?
    Old 05-29-2014, 12:44 PM   #5
    doaclnr is currently offline
    My Model: Z302
    My Engine: Volvo Penta 8.2 DP
    Send doaclnr:
    It looks like it goes into the intake water passage. Maybe some sort of quick warm up or over heating protection delio...
    doaclnr
    99 Z302 8.2 DP
    Old 05-29-2014, 02:04 PM   #6
    Status: In Limbo
    Send samimarkie:
    Vin# is 1ZJB25257M049673. I don't have the engine number handy. I'm on a field trip with my son riding in a bus to Chicago..I'll look if I have the drive number from some pictures..
    Old 05-29-2014, 02:11 PM   #7
    Status: In Limbo
    Send samimarkie:
    Prop numbers of that helps
    Old 05-29-2014, 04:02 PM   #8
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I've never seen on of those before. It looks like someone made an air bleed or a thermostat bypass by connecting the water passage of the intake manifold to the water jacket in the exhaust manifold. Since it is not standard Merc running gear...you will probably be OK if you omit it when you change your intake to the 4bbl. Just put a pipe plug in the exhaust manifold when you remove the mystery pipe.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-29-2014, 04:59 PM   #9
    Definitely not OEM as Steve stated.
    I can't find anything on it in any of the Mercruiser manuals.
    Old 06-02-2014, 08:45 PM   #10
    Status: In Limbo
    Send samimarkie:
    Might you know where I get a mercuiser service manual for a this 2000 5.7l? thx
    2000 Mariah lfishman12779 Introductions 3 07-19-2013 03:52 AM
    Mariah 2000 model vs Mariah 2006 SX21 jka Introductions 7 05-07-2013 07:14 PM
    2005 SX 19 with 4.3 Liter Mercrusier - Drain Plug Question cpincy General Maintenance 4 11-08-2012 05:05 PM
    cobra omc 4.3 liter ceedercreakmcbride Introductions 2 04-07-2012 01:00 AM
    4.3 liter engine problem navynickstl Mercury MerCruiser 1 05-11-2009 02:02 AM
    There are 386 users
