-   -   Water pump issues ... (http://www.mariahownersclub.com/forum/mercury-mercruiser/8584-water-pump-issues.html)
Hrdcor 07-30-2013 10:26 PM
Re: Water pump issues ...
Thanks guys ... Sounds like a good idea ... I found one online , a solid stainless steel one . I just need a pulley for it . Any idea where to get a pulley for it ???
ColoradoDiablo 07-30-2013 11:38 PM
Check HERE for the pulley.
Just make sure you have the right serial number.
That one might be the one you need , or might not. But you can do your own search , and at least get the part number if you want to look elsewhere for a better deal. :)
Hrdcor 07-31-2013 04:55 AM
Where would I get the serial # for my part ???
ColoradoDiablo 07-31-2013 04:59 AM
Sorry ,
Need the Serial Number from the engine.
Is your engine MPI or Carbed?
Hrdcor 07-31-2013 05:08 AM
Originally Posted by ColoradoDiablo (Post 47514)
Sorry ,
Carb.
ColoradoDiablo 07-31-2013 05:17 AM
Need the serial number to be sure.:wink_thumbup:
Hrdcor 07-31-2013 05:27 AM
Kewl... Thanks , I'll figure it out from here I'm sure ...
Hrdcor 08-13-2013 10:52 PM
Well my sea water pump cracked apart in the rear ,,, it's plastic ofcorse ... Any idea where I get the engine # to order the replacement parts ?
ColoradoDiablo 08-13-2013 11:05 PM
See if you have the drive # on the outer transom mount. That should do the trick.
Otherwise , it should be on a valve cover , carb cover , or maybe the right rear(port side) of the engine on the bell housing.
ColoradoDiablo 08-13-2013 11:08 PM
Is your 5.7 injected or carbed?
