trimming down problem
Old 06-29-2013, 02:37 PM   #1
Lewy is currently offline
My Model: 182
My Engine: 4.3L mercriuser
Send Lewy:
Default trimming down problem
used the boat the other week with no problems and left the boat on the mooring for a week with the leg virtually in trailer position.
today the leg started to go down but only a short way. trim back out again and no problem there. back in again and still no progress. Everything sounds ok and oil level topped up.
Tried trimming in whilst standing on the leg with the Misses on the switch and found this helped to get the leg in to around half trim.
Any suggestions what this might be? Motor on the way out? Piston rods? Trim position senders?
cheers fellas.
lewy
  • Old 06-29-2013, 02:56 PM   #2
    Default Re: trimming down problem
    Take a look here Lewy.
    It will help you diagnose the problem.
    Old 07-18-2013, 09:18 PM   #3
    My Model: 182
    Send Lewy:
    quick update.
    bought a replacement stainless steel bracket and new solenoids.
    all contacts cleaned and oil topped up.
    Pump seems to work fine and trimming out no issues. Trimming down is still not working right. Managed to get the leg ½ down by standing on the leg. Motor still runs when you get to this point but naturally changes tone somewhat.
    Any one else had this issue?
    cheers fellas.
    Old 07-19-2013, 07:16 PM   #4
    My Model: 182
    Send Lewy:
    thought I was going to have to pull the boat out and see if there were any problems with the rams.
    Today I decided whilst still on the water i'd try to reverse the up and down hoses at the pump to see if that would help in finding the nature of the fault.
    Anyway with hoses reversed the leg trimmed all the way down and then all the way out again!
    Put the hoses back to normal and so far all working ok. Not 100% sure what occurred but maybe I had one of the valves stuck and just reversing the action freed it, i'm not sure.
    So in conclusion, nice to see everything back to normal but cause of the problem is inconclusive and i'm expecting it to reoccur, some time, some place.!
    Old 07-19-2013, 07:35 PM   #5
    Well ,
    I'm glad it's working now anyway.
    If it were me I'd probably go ahead and flush the system and fill with new oil/fluid.
    Nice trick though.
    Old 07-19-2013, 09:08 PM   #6
    A little ingenuity goes a long ways sometimes...
    Old 07-26-2013, 12:44 AM   #7
    warner0308's Avatar
    warner0308 is currently offline
    My Model: z280
    My Engine: 454
    Send warner0308:
    I had same issue, I had to give it gas and trim down and the power of the motor would push out drive down, while I was trimming down. I park the boat in trailer mode and had build up on rams!!! Cleaned them and replaced seals works perfect. 30 seal kit and a little emrey cloth.
    Trimming out on my 98' 222, 7.4MPI Bravo I Chris B. Original Mariah Talk 0 06-03-2012 04:08 PM
    mercruiser 5.7 problem Brownboy Boating 101 3 10-13-2010 04:03 AM
    bad problem dmg5606 Mercury MerCruiser 3 06-03-2009 12:20 AM
    Trimming Speed for Outdrive Douglas Alderman Original Mariah Talk 1 08-25-2008 05:18 AM
    Name this Problem ShabahZ280 Original Mariah Talk 5 10-09-2007 01:41 PM
    There are 337 users
