Intermitten pop through carb higher rpm
Old 07-18-2013, 01:29 AM   #11
crashcourse101's Avatar
crashcourse101 is currently offline
My Model: Barchetta
My Engine: 4.3 alpha1 gen2
Gallery Images: 9
Send crashcourse101:
Default Re: Intermitten pop through carb higher rpm
When you say dist sensor are you referring to the ignition module? No, I did not change any internal distributor parts besides the button and yes I replaced coil. I have been stumped on this for a year and 20 hrs on the boat later. It runs great but I wonder if the service bulletin I found was because they put in a 1.65 instead but half a jet size for that many rpm?
I kept thinking ignition too Mikey but I am confused without just throwing parts at at.
  • Old 07-18-2013, 02:35 AM   #12
    The distributor sensor is located underneath the distributor. Here's a little information from sterndrives.com
    And here are the proper timing procedures at perfprotech.com
    Old 07-18-2013, 10:14 AM   #13
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Valve springs? If it sat for 10 yrs and never rolled over, some of the valves would have been open. These springs can take a "set", and have little pressure at the seat or open. I've seen some race engines I built that sat over winter that the springs on the open cyls were a quarter inch or more shorter when removed. I believe your springs should have around 75lbs of seat pressure. Just throwing it out there.
    Old 07-18-2013, 06:01 PM   #14
    My Model: Barchetta
    Gallery Images: 9
    Thanks guys I will keep digging and keep you informed
    Old 07-18-2013, 06:48 PM   #15
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    How are your risers?
    Have you checked the plugs for water/rust?
    Have you done a compression test?
    The reason I ask is this is what happened to me last month.
    Turned out the riser gasket had gone and this in turn did my head gasket!
    Hope i'm wrong
    Here's my thread
    Well that was a long week.
    Old 07-18-2013, 07:43 PM   #16
    My Model: Barchetta
    Gallery Images: 9
    compression is great 150 +/- 5 on all 6 cylinders no rust, black at threads with a great burn on tip with no full throttle stop check. I have a lot of no wake zone to idle through so I am thinking I have a clean condition at idle and a rich condition at wot.
    I see yours is a balance shaft too which mine is supposed to be but I am under the impression my motor has been replaced by an older version of the 4.3 non balanced shaft with the same carb from factory so my tuning could be off?
    Old 07-18-2013, 07:56 PM   #17
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    I'm glad to hear that sir
    So your motor is pre vortec then
    what carb is it? coorsmgood Original Mariah Talk 2 08-24-2010 02:18 AM
    What Carb do I have? ggrims Mercury MerCruiser 3 06-12-2010 06:13 PM
    4.3L Stalls/Kills at Higher RPMs abillmann Original Mariah Talk 3 08-07-2009 08:05 PM
    new carb ? boat man2 Original Mariah Talk 4 07-10-2009 06:14 PM
    Higher RPM's = Engine Sputter Roger Butterfield Mercury MerCruiser 10 06-24-2009 09:09 PM
    There are 338 users
