350 Mag, simple add on power
Old 04-01-2013, 01:39 AM   #1
TMRoper1669 is currently offline
Send TMRoper1669:
Default 350 Mag, simple add on power
I would like to try and get a little more power out of my 350 Mag, looking for better performance. Wondering if aftermarket carb would help? I have worked every prop, but feel like its motor not prop.
  • Old 04-01-2013, 01:55 AM   #2
    Default Re: 350 Mag, simple add on power
    You have a Weber 9600 series 4bbl now I believe. It is the same carb as the Edelbrock Performer Series 4bbl , and the Carter AFB Series 4bbl. They are good units.(I know my opinion)
    Why not get one of Edelbrocks Calibration kits and give it a try?
    How much are you willing to spend?
    You know the rule.......More Horsepower=Alot More Money
    Old 04-01-2013, 02:28 AM   #3
    Send TMRoper1669:
    I believe I have a Weber right now, I was wondering about a calibration kit, will that work on my existing carb? Do you think it would be worth while to invest in a new carb? I don't want to go crazy (money) with this, but I would like more power overall from acceleration to top end.
    Old 04-01-2013, 12:34 PM   #4
    What are you getting for topend speed now?
    Mercruiser did a good job with setting up the carbs on these engines. However , there is always room for improvement. When was the last time you did a major tuneup? How many hours are on the engine? How much weight is in the boat usually?
    I'd do a complete tuneup , rebuild the carb and calibrate it with edelbrocks kit.(I think it is #1480 for your Mag)
    Anything more than that and your going to get into some money fast!
    Next would probably be performance exhaust manifolds to get her to breathe a little easier , but there is 800-1000.00 easy just for parts.
    shore power tazzyou Original Mariah Talk 7 04-03-2011 11:37 AM
    power steering freeman81 Boating 101 7 02-04-2011 06:53 PM
    Not getting my power sweetness34 Mercury MerCruiser 3 09-10-2009 12:11 PM
    No dc power Brian Boating 101 3 06-04-2008 10:18 PM
    There are 351 users
