-   -   Will Motor Freeze (http://www.mariahownersclub.com/forum/mercury-mercruiser/7865-will-motor-freeze.html)
schevel 03-19-2013 03:24 PM
Will Motor Freeze
Looking for some opinions on this matter, had a beautiful weekend here in South Carolina and took the boat out for a while. They are calling for temperature here to be 26 Thursday morning now. It may only be this low for 6-8 hours. Should I pull all the plugs and drain water out of the block and add antifreeze again? Boat is an SX21 with 5.0 merc. Not sure if the deck lid will insulate enough, while it is sitting outside at a storage facility. Thanks in advance for any input.
Oregondunes 03-19-2013 03:37 PM
6-8 hours at that temp is not enough to freeze the block
mikeyt 03-19-2013 11:19 PM
Re: Will Motor Freeze
You could always run an extension cord out there, plug in a trouble light and leave it hanging in the engine compartment. That little extra heat should avoid any potential problems.
And never ever believe the weather 'forecasters'..... you will have better luck with a groundhog.
csterner 03-20-2013 02:15 AM
Sounds stupid but I have actually wrapped an old thick blanket over the engine and the outdrive. Not sure if it helped but it made me feel better!
allz28 03-20-2013 02:22 AM
It's so easy to pull drain plugs that I'd just do that. Wouldn't bother with antifreeze.
Motoxxx43 03-20-2013 04:24 AM
I'll 2nd the idea of an extension cord and light but like Oregon said, prob not long enough to freeze. It'll help you sleep better though!
Andy b 03-20-2013 07:14 AM
Not stupid at all, can't be as i've done the same thing :yes_grin:
Takes me 15 mins to drain down the motor after use, and helps me sleep when the temp drops unexpectedly this time of year
schevel 03-20-2013 11:00 AM
Thanks everyone for your input, no electric availablbe at the storage lot. Think I wll pull the plugs and drain the block, just so I can sleep!
ColoradoDiablo 03-20-2013 12:55 PM
I personally think that is a very wise decision.:wink_thumbup:
Andy b 03-20-2013 03:50 PM
+1 :wink_thumbup:
