Port & Polishing 4.3LX
Old 11-26-2012, 12:21 AM   #11
Default Re: Port & Polishing 4.3LX
Forgot to mention , My 4.3 has a roller cam.
Here is the specs
CAMSHAFT SPECIFICATIONS:
Cam Lift (Int./Exh.): .269/.273
Valve Lift (Int./Exh.): .404/.410
.050" Duration (Int./Exh.): 202/213
  • Old 11-26-2012, 02:38 AM   #12
    $143 and 10 for shipping sounds like a really good deal... The cam in my 450F cost a lot more than that...
    Old 11-26-2012, 04:02 AM   #13
    I'd be all over it , but it isn't a roller cam. The rest of my valvetrain is roller setup(lifters , pushrods , roller rockers , etc)
    Old 11-26-2012, 04:40 AM   #14
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Performance Camshafts, Lifter Kits and Matching Valvetrain for 6-Clylinder Chevy - Edelbrock.com
    Products > Automotive > Camshafts > Ch. 4.3L 90D V6 92-02
    Engle Racing Cams
    2000 Z302 Bow Rider
    Old 11-26-2012, 04:43 AM   #15
    Thanks for the info Oregon. I'll check em out
    Old 11-26-2012, 04:53 AM   #16
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Can u get away with just changing the camshaft? Will you still realize some significant gains?
    If its a roller cam, yes. Changing from a stock shaft to something aftermarket is probably one of the best and biggest things a person can do to increase performance.
    Compression wise 10:1 pistons are doable pretty easy as deck clearances, head gasket thickness, and head combustion chamber volumes are usually all greater than advertised. Another thing to remember is if you put a bigger camshaft in you may have 10:1 but with valve overlap it may have an effective ratio of only 9:1.
    Old 11-26-2012, 05:20 AM   #17
    I wish Lunati had the VooDoo cams in roller configuration!
    Old 11-26-2012, 05:23 AM   #18
    husker_fan's Avatar
    Send husker_fan:
    They do.
    Part #20090720 is a good one.
    Old 11-28-2012, 01:46 AM   #19
    Thanks for all the info guys
    Decided to shy away from porting the heads and I went with the Edelbrock 3714 cam since I am already running the Edelbrock 2111 intake.
    Edelbrock #350-3714
    Rollin' Thunder Hydraulic Roller Camshaft
    Chevy 4.3L 90° V6
    .479''/.488'' Lift
    272°/276° Adv. Duration
    Idle-5500 RPM Range
    Thanks again for all the great info!
    I'll post what happens when I get it finished and back in the water come spring.
    Old 11-28-2012, 04:27 AM   #20
    Gallery Images: 36
    Send Oregondunes:
    great choice. But Im with ya...I hate it. It's winter, the time you want to do upgrades and changes, then you gotta wait til spring to test your results.
    2000 Z302 Bow Rider
    Listing to port Majordo Introductions 4 07-24-2012 02:42 AM
    Fire Port jmills224 Original Mariah Talk 10 04-08-2008 10:16 PM
    Polishing Props S.L.P. Prop Talk 5 01-29-2008 08:56 AM
    Listing to Port dudders Boating 101 3 08-03-2007 01:27 AM
    Marine wax and polishing brands MariahMan General Maintenance 14 07-24-2007 01:48 AM
    There are 245 users
