-   -   oil in bilge (http://www.mariahownersclub.com/forum/mercury-mercruiser/7175-oil-bilge.html)
michaelb 07-16-2012 05:02 PM
oil in bilge
good day
i put my 5.7 merc up on plane the other day and then i heard an internal grinding noise for approx 3 seconds and then it quit. engine wont move now and i had a bilge full of oil. when i cleaned the oil out of the bilge i found one of the oil pan bolts, it had been sheared off.
i am planning on pulling the engine and looking for advice on this and what might of gone wrong in the engine.
thanks,
GregT 07-16-2012 05:06 PM
Re: oil in bilge
Can't tell you exactly what went wrong, but it was major. You may have thrown a rod or had a bad bearing but the sheared bolt and oil mean you blew the pan off or put a hole it in which means major engine repair. You'll have to pull it and see how bad it is.
mikeyt 07-16-2012 08:13 PM
Re: oil in bilge
Oil in the bilge is the least of your worries. I suspect catastrophic engine failure.....
DCB_MINDED 07-20-2012 03:01 PM
Re: oil in bilge
OUCH! Pieces flying off is never a good thing. Hopefully it is (relatively) minor
