Need help with diagnosing engine problem
Old 05-15-2012, 02:16 AM   #1
jarwiebe's Avatar
jarwiebe is currently offline
My Model: Z210 Shabah
My Engine: 5.7 LX Alpha I
Gallery Images: 2
Send jarwiebe:
Default Need help with diagnosing engine problem
Yesterday was our first launch this year and all went well till about an hour after launch. Was just coming up on WOT when all of a sudden a vibration started and the engine bogged down. Throttled back immediately and was able to limp back in to the ramp (10 miles up river) at 1500 rpms (anything above would setup a vibration). Oil pressure and temp remained normal. Oil level was normal and oil color was good. Determined cylinder # 5 was dead by pulling plug wires. Plug 5 looks good and has good spark. No backfiring coming through crab. Does this narrow it down to a bad exhaust valve or hole in the piston? I don't have the equipment to pressure test the cylinders but will see if I borrow/rent one later this week. Any thoughts that you may have would be appreciated?
Cheers
Jake
1996 Z210 Shabah
Mercruiser 5.7LX
Alpha One Drive
80 Lb. SX Smart Tabs
  • Old 05-15-2012, 06:48 PM   #2
    MTW
    MTW is currently offline
    My Year: 2008
    My Model: sx20
    My Engine: 5.0l alpha 1
    Send MTW:
    Default Re: Need help with diagnosing engine problem
    check prop for damage
    Mike
    Old 05-15-2012, 09:31 PM   #3
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    put your finger of the open spark plug hole. got any pressure when you crank it over ? a hole in the piston would surely produce no pressure..
    did you just foul a plug ? or a bad wire ?
    2000 Z302 Bow Rider
    Old 05-16-2012, 12:31 AM   #4
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Mike
    First thing I checked, prop ok but changed to my spare to be sure, no difference.
    Just finished a compression check:
    1 180
    3 15
    5 10
    7 175
    2 190
    4 175
    6 180
    8 175
    Looks like I have 2 dead cylinders not just 1 as I suspected. What is the best way to further narrow down the reason for the low compression? I suspect the head needs come off, is the correct?
    Your thoughts are greatly appreciated.
    Just occured to me, could this be a blown head gasket between # 3 & 5?
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 05-16-2012, 04:28 PM   #5
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    My first thought would be, blown head gasket. But either way, start working your way down to those cylinders. Not to scare you, but it could be a cracked head. Engines are designed for the gasket to be the weakest link (for obvious reasons) but sometimes strange things happen. Are you planning on doing the work yourself, or having it done?
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 05-16-2012, 04:46 PM   #6
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    I was thinking of doing the tear down myself and if it is just a head gasket I would do the reassemble as well. If it is more serious I would need to get it done.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 05-16-2012, 04:55 PM   #7
    DCB_MINDED's Avatar
    Send DCB_MINDED:
    Well, good luck! It's not a terribly difficult job if you have the tools, patience, and a little know how.... If you are going to do one, might as well do both sides, and get the heads checked and valves ground. Hopefully you are lucky and it is nothing more than a gasket! Let us know if you need advice or help with anything. Don't forget to post your end result so that it may help someone else in the future.
    Once again, GOOD LUCK!
    Old 05-18-2012, 02:45 AM   #8
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Started the tear down and this is what I found, blown gasket between 3 & 5. My concern at this point is the damage done to #5 cylinder wall. I know that it’s hard to tell in the pic's but what would you do? Give here new gaskets and closer her up or would you pull the engine and get the cylinder honed and new rings?
    I bought a complete top end gasket set so will pull the starboard head as well but first I need to decide whether gaskets is all that is needed or do I pull the engine?
    Any thoughts would be appreciated.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Old 05-19-2012, 01:46 AM   #9
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    My 2 cents, it appears from the marks on the top of your pistons "0.030" that your engine has already been overhauled at least once before. Depending on how deep the score marks are, our may not be able to rebuild it again. At this point, I would buy a thick FELPRO marine gasket set (SS compression rings with blue gasket) put it back together and try running it. Do another compression test and if you have decent compression and don't burn any oil...you're golden.
    Good luck!
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-19-2012, 02:25 AM   #10
    jarwiebe's Avatar
    Gallery Images: 2
    Send jarwiebe:
    Thanks for the reply Steve. I had a mechanic come take a look at it and hed said the same thing. By looking at it he detected damage to #5 pistion and figured that the rings probably are seized on it. He thought that it might work just regasket and go but recommended going the long block route seeing as the motor had already seen work some time ago. He will get me some pricing and then I'll need to make a decision. This wasn't in my budget but nor do I want to do a patch job and more then likely have to do it all over again shortly. If I do it right the first time I should be good to go.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    Mercruiser 5.0 EFI engine problem timgordon Mercury MerCruiser 4 09-13-2011 01:22 PM
    Engine stalling problem theeasynine Original Mariah Talk 11 07-06-2011 06:17 PM
    bad problem dmg5606 Mercury MerCruiser 3 06-03-2009 12:20 AM
    4.3 liter engine problem navynickstl Mercury MerCruiser 1 05-11-2009 02:02 AM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    There are 252 users
