-   -   blower switch (http://www.mariahownersclub.com/forum/mercury-mercruiser/5293-blower-switch.html)
z71forme 03-28-2011 02:09 AM
blower switch
I am trying to locate the blower switch on the boat that I purchased. I purchased a 1996 190 with a 4.3 L mercruiser. There are two switches on the left of the steering wheel. One I know is for the navigation, but the other I don't know what it is. i turned it on, but did not hear anything. I am supposing this is the blower. Any suggestions?
simpleaz 03-28-2011 05:45 AM
Re: blower switch
I believe so. That is where my blower switch is located. check fuses and inline fuses if you have them.
z71forme 03-28-2011 12:57 PM
Re: blower switch
Thank you will do that
z71forme 03-28-2011 12:59 PM
Re: blower switch
Do you know what the black knob is on the back of the boat abobe where you get onto the boat from the ladder. It seems to unscrew, but could not figure out what it is.
Dredd 03-28-2011 02:16 PM
Re: blower switch
Sounds like the gas vent. Is it slotted?
mikeyt 03-28-2011 07:59 PM
Re: blower switch
I agree that it sounds like the gas tank vent. Either that or its knob for the spring that you have to wind up to make the boat go faster.... ;)
btw....as for the blower switch, check the wiring at the blower if its not the fuse. Sometimes it comes loose & gets a bit of corrosion.
z71forme 03-28-2011 08:09 PM
Re: blower switch
Can you tell me where the blower is located? I looked last night, but had a hard time identifying it.:wink_thumbup:
z71forme 03-28-2011 08:10 PM
Re: blower switch
Yeah it is slotted, and unscrews. Thanks
mikeyt 03-28-2011 08:13 PM
Re: blower switch
Usually located at the stern on the port side. You should see some 3" or 4" flexible tubing running back there that goes from the blower to the actual vent.
