Electrical, starter clicks several times before starting
Old 10-24-2010, 12:27 AM   #1
ginodesico is currently offline
My Model: Z255 shabah
My Engine: 7.4 L Bravo III
Send ginodesico:
Default Electrical, starter clicks several times before starting
I have posted here a couples of times, looking for a solution to what would seem a simple solution. When I turn the ignition switch on, sometimes it starts, most of the time I get clicks. Replace the starter, starter relay, ignition switch, new battery, cleaned all connections today with steel wool from the grounds to the Mercathode & still get a click. Again, sometimes it turns over but not consistent. I had a electrician come over today with a volt meter & we still cannot find why it continues to do this at free will. Any help would be grateful & also need a wiring diagram for the hatch switch, electric seat switch. How to reconnect the wires. I have a 1996 Z255 Shabah 7.4 L Bravo Three Mercruiser. Thanks
  • Old 10-24-2010, 03:11 AM   #2
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Default Re: Electrical, starter clicks several times before starting
    Sounds like you're thorough so you are probably aware of this but I'll throw it out there. It sure sounds like the solenoid. I think on some Fords the solenoid is seperate from the starter. Maybe a similar setup? Idk, just an idea.
    Old 10-24-2010, 01:50 PM   #3
    Sorry to hear about your troubles and i agree that it sounds like the solenoid is going bad. If you would like to become a contributing member to the site, you will have access to all manuals / wiring diagrams necessary to help with the repairs.
    Old 10-29-2010, 02:30 PM   #4
    sc143kr07 is currently offline
    My Model: 214 jublee
    My Engine: 4.3l bravo
    Send sc143kr07:
    i had same problem on 1999 214 jublee and it was the starter i was buying had been rebuilt and it was bad the solonoid was intermittent.. solution i found always buy a NEW starter and be sure it is the correct torque and the correct teeth on flywheel
    Old 10-31-2010, 10:23 PM   #5
    Clay&Toot is currently offline
    Send Clay&Toot:
    I would check the grounds. All of them. I"ve had good luck running an extra straight to the starter. Could be a solinoid prob. You may have two. One remote{like a Ford} and another on the starter{like Chevy}. Good luck hope this helps. If not I'm sure someone on here can help you out.
    Old 11-01-2010, 01:35 PM   #6
    Send sc143kr07:
    I own a Mariah 4.3l Bravo three and I had the same problem and after electricans /mechanics finally the problem was solved ..I had been buying rebuilt starters and each starter had its own characterics some would just click like yours and some would start at random times never knew when it was going to not start.. Starter expert told me the bushings in the rebuilt starter had spots which were breaking down causing the random starts.. the clicking on the other starter was weak plunger on solonoid.. So be sure to get the CORRECT STARTER Correct torque and line the teeth up correctly no play in flywheel connections, you want the starter install to align with flywheen tight.. Solution NEW STARTER NO REBUILTS
    Old 11-01-2010, 01:43 PM   #7
    If you want to put a little time into it and be certain of what the problem is, there is a full starter diagnostics procedure here on our site.
    Old 12-22-2010, 03:45 AM   #8
    warner0308's Avatar
    warner0308 is currently offline
    My Model: z280
    My Engine: 454
    Send warner0308:
    i had the same prob. on a motorcycle. it was a ***** to find but it ended up being the neutral saftey switch!! you might want to check yours or even the kill switch, might sound funny but if there corroded they could act up during start.
    Old 12-22-2010, 03:27 PM   #9
    Dredd's Avatar
    Send Dredd:
    I think he forgot about his thread... he hasn't signed in since the day after, nearly 2 months ago.
    Old 02-15-2011, 07:45 AM   #10
    steventurner23 is currently offline
    My Year: 2003
    My Engine: 5.3L Mercruiser
    Send steventurner23:
    I have had the same clicking problems myself in my 2003 Mariah. I replaced both the circuit breaker and silenoid. Neither one of those fixed my problem, still clicks. im looking towards the starter as being the problem. But now im having trouble with my ignition. Im not getting any power to my ignition at all. Does anyone know if the power wire to the ignition has an in line fuse or not????
    Trim Motor Doesn't Work - Clicks on Down but Nothing on Up Dredd Mercury MerCruiser 5 08-04-2021 06:08 PM
    Not always starting Snowaterdude Original Mariah Talk 1 09-20-2009 03:31 AM
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    There are 374 users
