Electrical, starter clicks several times before starting
Old 02-16-2011, 10:37 PM   #11
al levy is currently offline
My Model: 272 shabah
My Engine: 7.4 bravo 111
Send al levy:
Default Re: Electrical, starter clicks several times before starting
Originally Posted by steventurner23 View Post
I have had the same clicking problems myself in my 2003 Mariah. I replaced both the circuit breaker and silenoid. Neither one of those fixed my problem, still clicks. im looking towards the starter as being the problem. But now im having trouble with my ignition. Im not getting any power to my ignition at all. Does anyone know if the power wire to the ignition has an in line fuse or not????
There is a main fuse located rite on top or near the starter relay. I know everybody says it clicks but you must find out where the click is coming from. It can click from the top relay or from the starter solinoid.
  • Old 09-12-2015, 01:23 PM   #12
    jus lofen is currently offline
    My Model: Z260
    My Engine: 7.4 Bravo III
    Send jus lofen:
    Default Re: Electrical, starter clicks one time as you turn the key
    Good morning,
    I am having issues with my solenoid just a single click when I turn the key. my volt meter is showing 13-14volts, but not real sure if its a starter issue or a battery issue?! I have a 4 bank charger/maintainer, and everything else seems to work fine. Generator starts right up, so makes me lean towards the starter solenoid..
    Old 09-12-2015, 02:09 PM   #13
    Post #7 in this 4 1/2 yr old thread. Trouble shooing STICKY
    Trim Motor Doesn't Work - Clicks on Down but Nothing on Up Dredd Mercury MerCruiser 5 08-04-2021 06:08 PM
    Not always starting Snowaterdude Original Mariah Talk 1 09-20-2009 03:31 AM
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    There are 378 users
