4.3 cylinder head
Old 08-20-2010, 06:36 PM   #1
KJSX19 is currently offline
My Year: 2006
My Model: SX19
My Engine: 4.3L Alpha
Send KJSX19:
Default 4.3 cylinder head
Hello guys,
I recently got back from overseas and realized that the person that was watching my boat did not winterized like i asked. I have a 2006 SX19 with a 4.3 mercruiser. So now the left cylinder head and both exhaust manifolds are cracked. My question is will a head from a automotive 4.3 GM engine work. I can find those a lot cheaper than the mercruiser ones. Any help will be greatly appreciated. New to the forum thing but I thought this was the best way to find things out. Thanks for the help
  • Old 08-20-2010, 07:19 PM   #2
    Default Re: 4.3 cylinder head
    Hopefully it didn't also crack the block & the outdrive. It is SO important to properly winterize a marine engine. I dont believe it would be a wise idea to use an automotive head though. Here's a technical advice article on the subject:
    Topic: Marine Engines vs. Automotive
    Question: Is There Really Any Difference Between a Marine Engine vs. Automotive?
    Response: Contrary to what many people claim, there truly are several differences between the automotive engine and marine. These differences prevent automotive products from performing as well as the intended marine engine. Many people attempt to save money by utilizing an automotive engine rather than marine, however in our experience these situations rarely save money in the end. Be very careful with companies who claim to offer engines not being Marine Grade, but still being the same, or compliant, or some other fancy terminology. In the end the fact still remains that you get what you pay for.
    The freeze plugs are of a corrosion inhibiting material.
    The head gaskets also utilize corrosion resistant construction.
    The valve guides utilize corrosion resistant construction.
    The water pumps are intended for a marine operating environment (seals and bearings).
    The camshaft is designed to marine duty requirements as needed to move a boat versus a car.
    The overall duty cycle of a marine engine is very different than that of an automotive application. When was the last time your thought of running your car at full throttle for a sustained period of time?
    4.3 , 4.3 cylinder head
    Cylinder block warrenpark65 Volvo Penta 0 05-28-2010 08:27 AM
    Water in cylinder azboatman Original Mariah Talk 12 07-08-2009 08:23 AM
    How do I identify the cylinder numbers on a 5.7 EFI? DGR-Z246-98 Original Mariah Talk 2 04-30-2009 12:05 PM
    Master Cylinder for breaks turfguy99 Trailering and Tow Vehicles 1 07-29-2008 08:12 PM
    There are 337 users
