Found Alpha 1 Plate Broke....
Old 11-16-2009, 02:14 AM   #1
95Z212's Avatar
95Z212 is currently offline
My Engine: 5.0LX Alpha 1
Send 95Z212:
Default Found Alpha 1 Plate Broke....
I was putting the boat in my shop tonight, where it will sit all winter next to my plow trucks. I was fiddling around with the boat and took the prop off See picture below....
This is what I found :
Can anyone tell me what the hell this thing does #1, why it broke, and its 'technical' name so I can get a new one on order? Also, my prop has a crack in the 'inner' ring that is on the inside (not the side facing the water, the one facing the lower unit. I will get a picture of the prop tomorrow.
I guess this forces me to get a new SS prop. I'm loving the fact that my baby gets to stay in the radiant heated floor and climate controlled shop so I can stare at her all winter
1995 Shabah Z212 V8
2012 CRF 450R
My location
  • Old 11-16-2009, 06:22 AM   #2
    Default Re: Found Alpha 1 Plate Broke....
    Hi 95Z212,
    I believe that is called the 'Propeller Anode' and it is there to protect the lower area of the outdrive from being eaten away by Galvanic action between the steel and aluminum parts. It's a sacrificial Anode (also called zinks) designed to slowly dissolve away and is a replaceable item. From what I can tell from the picture, it doesn't seem to be broken, the two "notches" are for access to the two bolts that hold it on.
    Now looking at your first picture, it appears that the large round Anode in the cavitation plate is missing (big hole above the prop) which might explain the condition of the 'Propeller Anode'. Check your outdrive to insure all the Anodes are present and in good condition (two on the gimble ring, one on the back of the cavitation plate [the missing one] and possibly one on it's front, one on the end of each trim ram and lastly, the Prop Anode), if not, install/replace then as needed, otherwise it will accelerate the wear on the remaining anodes
    Good luck,
    Old 11-16-2009, 10:29 PM   #3
    95Z212's Avatar
    Send 95Z212:
    The one above the prop is there, its just the angle of the picture/light, and the fact that i sanded, primed with 2 coats and shot 2 coats black, with 1 clear (just never taped it of)
    The one that i say is 'broke' is there. Hectic day at work, so no new pictures. The notchs I understand are there to get to the bolt (on the anode itself) the little tabs that come down where the bolt goes, is broke on the side of my last picture, and the other side is well on its way to breaking. How much would this thing cost?
    I'm probably going to buy a 4 blade aluminum prop to make sure I like the pitch, then replace it with SS... I'd rather waist $150 to find out I don't like the prop, than $300+...
    Thanks!
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 11-16-2009, 11:49 PM   #4
    mariah bob is currently offline
    My Model: 1996 200 Shaba Limited Edition 5.7 Alpha One
    Send mariah bob:
    I believe painting them renders them useless.
    Old 11-17-2009, 06:26 AM   #5
    Mariah bob's right, painting the "Zinks" render them useless.
    If you want to change them all, there's a kit on ebay (click here) for $37.50 + $5.60 for shipping or for just the Prop Anode, $6.00 + $7.00 for shipping, again on eBay (click here).
    Beware of the differences between an Aluminum and SS prop of the same pitch. Aluminum props flex under load (like during take-offs) so they de-pitch slightly where as the SS prop wont flex or change pitch and may hurt the hole shot slightly. See if your marina has any test props you can try first.
    Good luck,
    Old 11-17-2009, 07:52 PM   #6
    95Z212's Avatar
    Send 95Z212:
    Will do guys thanks... As for the anode's, its just paint mist. I didn't direcltly paint them... The picture is at a bad angle.
    1995 Shabah Z212 V8
    2012 CRF 450R
    My location
    Old 11-20-2009, 07:52 PM   #7
    Rdrdon's Avatar
    Rdrdon is currently offline
    My Model: Shabah 200 Limited Edition
    My Engine: 5.7L, Alpha One
    Send Rdrdon:
    I would clean the paint off really well with thinner & don't use a wire brush. It the anodes aren't working all sorts of weird problems start happening due to galvanic corrosion.
    Z192 Factory Console Plate Replacement/Switch Location? jkboliphant Original Mariah Talk 7 09-23-2010 11:55 AM
    I Broke Our Boat Today SEMIJim Chit Chat/Off-Topic 9 07-25-2009 01:37 PM
    Coast Gaurd Passenger plate Jason_Smith008 Original Mariah Talk 3 08-28-2008 06:58 PM
    found one illini1 Mariah Boats For Sale & Wanted 1 08-18-2008 02:04 PM
    Wanted: MARIAH original sticker / type plate mariah2350cz Mariah Parts For Sale & Wanted 1 12-01-2007 01:56 PM
    There are 237 users
