how to access wiring diagrams?
new motor delivery on monday could someone tell me how to access wiring diagrams so I have a back up to the digital pictures I took ?
Re: how to access wiring diagrams?
they're here.
just find your motor, and look for the installation or the service manual, and locate the electrical section. That should help you out! |
sure does thank for your help!
Says I cannot access page
You need to be a paid member to access the manuals. The cost is less than the cost of one of the manuals would be.
What does it cost? I see nothing that states this. And what kind of imfo does the manual give ? Thanks
Sorry, I should have given you that information. Go to the home page and you will see a "contribute" button - the tiered contributions start at $15 annually. I have a newer Mariah and the manuals on those show next to nothing, I'll let someone else chime in for the detail of the older manuals.
Everything says go to contribute to access manuals but I bought the silver membership and can not find these manuals on the site. Is there some comprehensive archive that can be accessed? Similar to the one listing benefits of becoming a member?
There are 7 pages of manuals in the section entitled "Original Mariah Manuals and Supplements" covering boat equipment and the link for Mechanical Service, Repair & Operating Manuals is at the bottom of the Maintenance & Repairs forum. If what you are looking for is not there, they likely haven't found a copy to upload onto this site.
Send a PM to the site Admin ShabahZ280 if you can't figure out how to access or have a look at the FAQ's |
I was also looking for some wiring diagrams, but this site tells me I do not have enough privileges to get to them. I have a registered account and a recently bought Z218 Cuddy. I have a bilge pump dilemma I am trying to solve and I am having trouble get any useful information. The boat apparently came with an original Attwood V1250, which is now obsolete and a float switch. Based on what I see, there are 2 wires from the pump, 2 from the switch. Two of them are crimped together (I believe they are the "+" wires). The boat harness then connects with what I think should be a hot wire, a neutral and one that only gets hot when the bilge switch is toggled. When I put a meter to it I only get power when the switch is toggled and with the switch off there is no power to either off the legs. That doesn't make sense if the float switch is supposed to work... Getting behind that dashboard seems a huge deal and I wondered if I don't have a simple fuse issue. Or maybe a bad wire. Can anyone help?
| All times are GMT. The time now is 06:04 PM. |
