-   -   Fuel Tank Leak (http://www.mariahownersclub.com/forum/mercury-mercruiser/2362-fuel-tank-leak.html)
Roger Butterfield 05-27-2009 05:15 PM
Re: Fuel Tank Leak
Darrell, thanks for the tip. I called and let the guys know they need to put a thick coat of marine (rubberized) paint on the bottom and sides. Very good idea! Maybe this will last a few years :-)
Cliff et al - the tank is v-shaped and, I'm not sure if there is a drain hole in the bulk-head stringer or not but it sure appears not since there is all that water inside. Wondering how in the world water got in there in the first place? I definitely need to ensure a flow-through hole is drilled though.
Roger
