50 Amp Circuit Breaker Pops
Old 07-14-2008, 11:37 PM   #1
AndyFL
Posts: n/a
Status: Guest
Gallery Images:
Default 50 Amp Circuit Breaker Pops
My 2006 Mercruiser 4.3L TKS 190HP I/O ran fine for about 45 minutes before dying/stalling out while underway and without warning at about 1800 RPM. I tried to start up the engine but it was completely dead; no engine cranking sound, no audio warning alarm either. I checked all electrical gauges and all were out. I then checked all battery connections, fuses, wiring, etc and all seemed normal. I resetted the 50 Amp "Reset" button for the electrical overload protection system and finally the engine started up. I turned around back to port and engine ran fine for 10-15 mins, but it stalled again at about the same RPM and conditions as before. After resetting the overload electrical system breaker for a second time, the engine finally restarted and I was able to get safe to port but only at a very low RPM and almost idling speed.
I tested the battery and is OK, checked all wires, wiring harness, etc., all everything looks normal.
Anyone had experienced this problem? Any idea what might be causing this?
Thanks, Andy
  • Old 07-15-2008, 01:10 AM   #2
    Hmm, if it's tripping your main circuit breaker, I'd say you've got a serious electrical problem with the engine. This might require professional service.
    I'm wondering if it could be your alternator possibly overloading the system?
    Old 07-16-2008, 04:56 AM   #3
    dieselwiezil is currently offline
    My Model: 2000 Mariah 212 5.7V8 Mercruiser Alpha I 21p mirage plus 48-13702
    Send dieselwiezil:
    Im not a "boat mechanic" but you got a major short to ground. If you suspect your alternator, detach the larger wire that comes from the starter or 12v source. That will cut the supply to the alt. Another thing I have run into is look CAREFULLY around your engine and make sure there are no wires rubbing anything on the engine or any type of bare metal grounded to the boat. Iwould bet thats your problem over the alternator.
    2000 Mariah 212 Mercruiser 350
    2002 F150 Supercrew
    1996 F250 Diesel lots of power goodies.
    "Out of everything I have, I still prefer riding MARIAH"
    Old 07-23-2008, 11:35 PM   #4
    AndyFL
    Posts: n/a
    Status: Guest
    Gallery Images:
    Thanks for your replies guys.
    As I was already aware, troubleshooting an electrical problem is not an easy task. I am at a dead-end here; I had been told to check all wiring, connections, harness, ignition coil, alternator, belt tension, trim pump, starter, circuit braker, etc., but I can't seem to locate and pin point my engine's culprit. I am hopeless and will have to let a Merc mechanic diagnose and repair my engine. I am sure he will find what's wrong fairly quick.
    I'll keep you posted as to what turns out and what's the final tab.
    Old 07-28-2008, 08:18 PM   #5
    In a situation like this, I would recommend taking it to a service facility. 50amps is quite a jolt if you came in the middle of the circuit path. Better safe than sorry. Let us know how it turns out!
    Old 07-29-2008, 04:26 AM   #6
    Send dieselwiezil:
    I have a feeling it will be a quite simple fix. I think your problem is from your batt to starter to alternator. All those wires are a pretty good gauge wire. Any bare spots in those wires would cause this problem. Do you have ANY mechanical background? If not, than I agree the best thing to do is take to a professional. If you would like some troubleshooting help shoot me a PM.
    2002 F150 Supercrew
    Old 07-29-2008, 09:12 AM   #7
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    See what happens when you play with electricity and yourself at the same time?
    Tony
    Perth, Western Australia
    Old 11-03-2008, 05:21 AM   #8
    AirNavy's Avatar
    AirNavy is currently offline
    My Model: Z215 Talari
    My Engine: 5.7L Alpha One
    Send AirNavy:
    I'm not sure if this one has been fixed yet, but if all of the insulation on the wires looks good and there's no visible corrosion at the terminals I would replace the circuit breaker. The contacts in the breaker can corrode causing a high resistance which will trip them well below their rated current because of the heat genertaed by the extra resistance.
    Mickey
    AEC (AW) U.S. Navy
    Old 11-03-2008, 07:42 PM   #9
    AndyFL
    Posts: n/a
    Status: Guest
    Gallery Images:
    Mickey:
    The problem has indeed been resolved and your suggestion hit the nail right on the head.
    I ended up replacing the breaker, ($60.00 part), and problem solved. When I removed the old one, it wasn't corroded at all, but found that one of the two male connectors was loose and had a lot of play, and with engine vibration, that kept tripping the breaker.
    Thanks, Andy
    Old 02-21-2017, 02:16 AM   #10
    IowaBoy is currently offline
    My Model: Runabout
    My Engine: 3.0
    Send IowaBoy:
    Default Re: 50 Amp Circuit Breaker Pops
    Sold my Harley and am now a boater here in Florida. I'm a DIY guy but boats are pretty new to me.
    After a day boating I was doing my usual clean up and flushing the engine. Tried to crank it over and nothing! I noticed the battery was drained. Hmm. All I was getting was a click that sounded like it was coming from the battery shut off. I've been charging the battery and checking wires all over and noticed the 50 Amp reset button. I pressed it a number of times and held it in. I got one good crank out of my next attempt at starting it. Now nothing again.
    So. One could say the 50 Amp is faulty. It looks old and rusty so I'm not surprised. However, what would have drained the battery? Is there juice running back through the 50 Amp from the alternator?
    I still wouldn't expect the battery to be drained after 5 hours of boating... would I?
    Thanks much to anyone with a though or two.
    Z 240 underdash Circuit Board WetWilly Original Mariah Talk 10 04-02-2012 02:58 AM
    circuit breakers adornare Original Mariah Talk 3 06-12-2008 07:00 PM
    There are 376 users
