Greetings
Old 09-28-2021, 07:57 PM   #1
thigpen454 is currently offline
My Model: z22 limited Shabah
My Engine: 454 Mag MPI
Send thigpen454:
Default Greetings
Hello everyone, I have a 1997 Shaba Z22 with a 454 Mag MPI that seems to be idling low to the point that it cuts off while sifting between forward and reverse. Is this something that can be adjusted up via electronics?
Thanks!
  • Old 09-29-2021, 12:08 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Greetings
    Have you tried cleaning the carbon off your idle air control valve and your throttle body. 9 times out of 10 that will solve a low idle stall issue.
    GregT likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 12-23-2021, 08:52 PM   #3
    Send thigpen454:
    I replaced the IAC but it made no difference. I think it might be a bad shifting cable or the shift interrupt switch, which I still have not been able to locate.
    Thanks!
    Old 12-23-2021, 09:54 PM   #4
    My Model: Z280
    Bravo drives do not have a shift interupt switch.
    GregT likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 12-24-2021, 02:02 AM   #5
    Which might explain why the OP cant locate it....
    GregT likes this.
    There are 283 users
