High Oil pressure
Old 08-14-2017, 03:45 PM   #11
mrbillstl is currently offline
My Model: Davanti
My Engine: 7.4 Bravo one
Send mrbillstl:
Default Re: High Oil pressure
Did you replace the oil pump? The pressure regulator in the pump may be stuck. Since all this happened after an oil/filter change, I'd replace the filter with the correct OEM filter (Not an after-market) and the proper weight of oil that is listed in your owners manual. 80 psi is totally our of specs. I would check the oil pressure with a hydraulic gauge screwed into where the sending unit is to verify oil press.
Good Luck!
MrBill
  • Old 08-14-2017, 10:57 PM   #12
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    I agree with replacing the oil filter. You may have one not meant for your engine. By the way, for the 4.3 V6 engine, the oil bypass valve is not in the oil pump but rather in the oil filter mount and prevents oil from being blocked by a clogged filter. It does not limit the overall oil pressure but limits the difference in pressure at both ends of the filter to no more than about 15 psi.
    Old 08-16-2017, 11:46 AM   #13
    My Model: Davanti
    Send mrbillstl:
    I checked a MerCrusier service manual and all the Mercury engines have the same engine oil pressure spec of 30 - 60 psi except for the 7.4L which is 30-70psi.
    MrBill
    Old 08-16-2017, 03:08 PM   #14
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    Good Luck!
    MrBill
    I agree with MrBill that you should use a more accurate gauge to determine for sure where your oil pressure numbers are running. Sometimes the sending units can be inaccurate as much as 10 psi.
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    high Oil pressure fun on the water Introductions 1 08-12-2017 02:45 PM
    Oil Pressure andyc Mercury MerCruiser 4 06-22-2011 08:20 PM
    High-pitched alarm sound & high temp at high RPM petemcrunnel Original Mariah Talk 7 06-15-2011 05:57 PM
    Oil Pressure my97camaro General Maintenance 0 06-15-2010 03:11 PM
    Oil pressure too high??? DGR-Z246-98 Original Mariah Talk 6 11-02-2009 03:34 PM
    There are 334 users
