anti-siphon valve
Old 08-08-2017, 09:41 PM   #1
murty is currently offline
My Model: Diablo
My Engine: 4.3 Merc
Send murty:
Default anti-siphon valve
Where is the anti-siphon valve on 1993 Diablo 18?
  • Old 08-09-2017, 02:22 AM   #2
    My Model: Z276
    Send Brian Belcher:
    Default Re: anti-siphon valve
    It SHOULD be the fitting that is screwed into the 90 degree, pick up tube fitting, screwed into the fuel cell. It is a combination barb fitting and anti-siphon.
    If you are going to take it out, be prepared for it to break off in the pick up tube fitting. They used some pretty tough sealant when they put it together back at the Mariah plant. IOWs, go ahead and get the pick up tube assembly. If you do get it out without breaking it, you can send the tube back.
    ALSO, Teflon tape is NOT gasoline proof. You'll need the tape that is rated for gases. It has the yellow cover instead of blue.
    anti-siphon valve , diablo
    Water intrusion check valve? dafucwuzat Mercury MerCruiser 2 03-31-2016 10:45 AM
    Anti-siphon Valve - which one rhinoz General Maintenance 2 06-13-2013 01:51 AM
    Anti Fouling Paint - To do or not to do.. Redmond General Maintenance 10 12-21-2011 02:11 PM
    Mariah 180 SE 3.0LX needle valve sticking Stuart Johnson Mercury MerCruiser 1 06-21-2010 02:49 PM
    Positive Crankcase Ventilation (PCV) valve Billyclub Original Mariah Talk 1 08-19-2009 04:37 AM
    There are 370 users
