Intermittent Fuel Starved 5.7
Old 07-17-2017, 04:18 AM   #1
Scottie1961's Avatar
Scottie1961 is currently offline
Status: Gold Contributor
My Model: Z202 Shabah
My Engine: 5.7L Alpha One
Send Scottie1961:
Default Intermittent Fuel Starved 5.7
I guess the old addage that you can't fix it if it ain't broke holds true. Changed spark plugs, rotor and distributor cap. Also changed out the fuel/water separator cartridge. Fired right off on the muffs so we went to the lake. Ran like a top and pulled the grandkids on skis. Then pulled nephew out on slalom and the thing started cutting and coughing like it was out of fuel even though I had over 1/4 tank.
Pulled him over to the marina and added 12 gallons but no help. I let the thing sit for a while and got up on plane and then it took off like a banshee. After about 5 minutes same coughing and cutting out. It's like it's running rough but seems like fuel starved to me. Pretty sure it's not vapor lock and engine temp and oil pressure stay consistent.
I took it back out today and ran fine for about 15 minutes. Started same scenario all over again. The only thing I did related to fuel flow is change the filter. I primed it and it obviously is working. Could some crud have gotten knocked loose inside the line when I changed the filter? One thing that I did notice was the new filter (mercury) was shorter than the one that was on the boat (quicksilver). The diameter was identical so I can't imagine this being an issue. I'm pretty stumped here since it runs so well for a while then craps out. Thanks for any ideas or guidance.
1995 Mariah Z202 Shabah
5.7 Alpha One Gen II
  • Old 07-17-2017, 03:42 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Intermittent Fuel Starved 5.7
    Take the filter off and empty contents into a clear container. Let it sit to see if you have water in the fuel. The water will sink to the bottom.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-19-2017, 02:02 AM   #3
    Send Scottie1961:
    OK the good news is the gas out of the filter looks crystal clear. Guess I didn't realize how much the dyes in gasoline have changed over the years. For those of us who grew up around tractors, the amber color of gasoline or the dark green of diesel were visible in the glass bowls at the bottom of the shutoff valve. Looks like a very light yellow color now.
    The bad news is I still don't know what's causing the fuel delivery problem.
    Old 07-19-2017, 04:31 AM   #4
    My Model: Z276
    Send Brian Belcher:
    Pull the coil off and ohm it out across the primaries and then from the primaries to the output, secondary. The primaries (+ and -) should be zero but can have a little resistance. The secondary side will be in the 20k and lower range. Your problem sounds like a coil going bad. Hudson Steve can prolly give you the exact readings on your coil. He be smart like that.
    Old 07-19-2017, 02:10 PM   #5
    Send Scottie1961:
    OK, that's a great idea. I'll give that a shot and see what I find. Thank you for the info Brian!
    Old 07-19-2017, 02:21 PM   #6
    Mariahsteve12 is currently offline
    My Model: Z202
    My Engine: 350
    Send Mariahsteve12:
    Hey Scottie. Did the coil fix your problem? I have the same boat with the same problem.
    Old 07-19-2017, 02:26 PM   #7
    Send Scottie1961:
    I'll know more tonight when I can pull the coil off. I'll keep you posted on what I find.
    Old 07-19-2017, 06:13 PM   #8
    My Model: Z280
    I assume you have a Thunderbolt IV ignition system with the standard Mercruiser coil (392-7803A4). If so then the primary resistance should be 0.60-0.80 Ohms and the secondary resistance should be 9,400-11,700 Ohms.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-19-2017, 07:10 PM   #9
    Send Scottie1961:
    Thanks for the info Hudson River Steve!
    Old 07-20-2017, 01:04 AM   #10
    My Model: Z276
    Send Brian Belcher:
    I toltd't y'all Steve would have the answer !!!
    Intermittent Alarm Kitto Original Mariah Talk 1 08-11-2014 12:54 PM
    Intermittent Alarm oneilld Boating 101 9 08-29-2010 01:48 PM
    Intermittent Starting Problems Weezer Original Mariah Talk 4 11-20-2009 12:12 AM
    Intermittent Electrical Problem jwpilger General Maintenance 13 08-13-2009 02:44 AM
    intermittent shutdown love2boat Volvo Penta 6 07-14-2008 02:41 AM
    There are 499 users
