Question about running motor out of water
Old 06-27-2017, 12:44 AM   #1
Tlolesen's Avatar
Tlolesen is currently offline
My Model: 182
My Engine: 4.3 merc
Gallery Images: 3
Send Tlolesen:
Default Question about running motor out of water
I have a 2001 Shabah 182 with a 4.3 liter V6 with a alpha 1 stern drive. I keep the boat in a storage yard and wanted to know what everyone thinks about starting it without water for a minute or so to make sure it will start before I leave for the lake. I take it home after the lake to rinse it out with muffs, I would like to pick it up at the yard and make sure it will start before I get to the lake and not go back home to use the muffs. I want to avoid driving to the lake and needing to jump the battery or something else.
  • Old 06-27-2017, 12:51 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Question about running motor out of water
    Following
    John
    Old 06-27-2017, 01:10 AM   #3
    1996 Mariah Z252 is currently offline
    My Model: Z255 Shabah
    Send 1996 Mariah Z252:
    It is fine to try to start it for a few seconds. Once it starts you really only have less then a couple of seconds before the engine overheats. Just see if it will turn over and as soon as it does shut it off.
    Thank you 1996 Mariah Z252 for this useful post!
    Firestone (06-27-2017)
    Old 06-27-2017, 01:36 AM   #4
    GaryDoug's Avatar
    GaryDoug is currently offline
    My Model: Z202
    My Engine: 5.7L Bravo III
    Send GaryDoug:
    Actually the engine's coolant thermostat won't even open until a few minutes after starting, so the engine won't overheat in that time. There will be residual water in the engine block and heads that will circulate in the meantime. My concern would be for the drive's water pump and that could be damaged by more than a few seconds of dry operation. Is there no running water at the storage yard?
    Thank you GaryDoug for this useful post!
    Old 06-27-2017, 01:37 AM   #5
    Originally Posted by GaryDoug View Post
    Actually the engine's coolant thermostat won't even open until a few minutes after starting, so the engine won't overheat in that time. My concern would be for the drive's water pump and that could be damaged by more than a few seconds of dry operation. Is there no running water at the storage yard?
    On my boat it will burn out the impeller in a few seconds if it doesn't have water. And my coolant temperature seems to open right up as it starts.
    Old 06-27-2017, 01:43 AM   #6
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    If your thermostat is opening right up then there is something wrong with it. It should not open until maybe 180 degrees (some are 160) and that would take at least two minutes to occur with a cold engine. Don't confuse the engine coolant circulation with the external one that merges with it before the thermostat. You will get normal flow from the water discharge at a cold start but most of that bypasses the engine until the thermostat opens.
    Old 06-27-2017, 01:45 AM   #7
    Oops! I thought you ment when it would start reading a temperature. Yeah it takes like 5 mins of idling for it to get up to operating temperature
    Old 06-27-2017, 01:45 AM   #8
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    I don't run the impeller even with the muffs just let it idle in neutral.
    Old 06-27-2017, 01:48 AM   #9
    Tlolesen's Avatar
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Also on mine there is no engine coolant but the lake water.
    Old 06-27-2017, 01:50 AM   #10
    GaryDoug's Avatar
    My Model: Z202
    Send GaryDoug:
    What! The water pump impeller in the lower unit is always turning anytime the engine is running. Otherwise the engine would eventually overheat. Are you thinking of the bilge pump? In an Alpha drive, the shifting is done in the lowest part of the unit just ahead of the propeller.
    The lake water IS the engine coolant. That water stays in the engine until it is flushed out by the external water pump in the drive. When the thermostat opens, the external water then flows thorough the engine.
    bibleg2015 (06-28-2017)
    "Brackish" water running 96MariahZ220 General Maintenance 3 10-15-2014 11:29 PM
    Another motor swap question Weezer Original Mariah Talk 5 09-04-2012 02:46 AM
    running with a water hose/ear muffs midwest mariah Original Mariah Talk 17 06-13-2011 02:44 PM
    Salt Water Running Y-Knot Sea Fox - Mariah Talk 1 04-28-2011 07:47 PM
    Motor operation with water in fuel tank dennis0329 Original Mariah Talk 1 09-21-2009 07:49 PM
    There are 304 users
