-   -   Outdrive oil ? (http://www.mariahownersclub.com/forum/mercury-mercruiser/10917-outdrive-oil.html)
Otter 07-01-2016 01:08 AM
Outdrive oil ?
1999 merc alpha 1 gen II outdrive, pervious owner had cut the resivoir gear oil line and put a plastic splice fitting in the hose (to help avoid stress on the plastic transom through haul fitting) . Well the plastic splice broke while I was on the water and leaked causing the low revivoir alarm to sound. Drove back to dock an I've since fixed the splice with a brass hose coupler. Should I drain and change the outdrive oil or just top off the resivoir and run it though the summer?
Firestone 07-01-2016 03:35 PM
Re: Outdrive oil ?
Can you see if you have water intrusion in your resivoir?
Firestone - 2000 Mariah Z202 5.7L MAG Alpha I Gen II
Otter 07-02-2016 02:55 AM
Re: Outdrive oil ?
Went ahead with a drain and change today.
Firestone 07-02-2016 02:57 AM
Re: Outdrive oil ?
It really is the safest choice verse shelling out $ for a new lower end.
