Whirring noise from bravo three
Old 05-30-2016, 01:13 PM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Whirring noise from bravo three
Hi all. Had my Talari on the lake yesterday. When I got home and had the muffs on it to flush the motor out, I noticed a very light whirring noise coming from the top of the lower unit. Sounded like it was coming from right below the top cover where the driveshaft goes in. It's not loud and doesn't have any ticking or clunking noise. Is that normal? Boat ran great all day long
  • Old 05-31-2016, 03:09 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Whirring noise from bravo three
    I assume gear lube is at proper level in the reservoir. Try running on the muffs again, while running shoot some grease into the gimbal bearing zerk fitting. If you hear a noticeable change your bearing might be on its way out.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-31-2016, 03:31 PM   #3
    Send Txtruckerpaul:
    Thanks Steve,
    Oil level is correct and I shot some grease in the gimbal zerk. Is a little, and I mean just a little, noise normal?
    Old 05-31-2016, 05:20 PM   #4
    My Model: Z280
    Between all the gears, bearings, u-joints etc in that area there is bound to be a small amount of noise. It's tough to diagnose without being there. Do you hear anything when on the water, specifically when you are turning hard?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-31-2016, 05:34 PM   #5
    Send Txtruckerpaul:
    No sir, don't hear anything while its in the water. no clicking noises or anything in hard turns either. I'll agree, there's bound to be a little noise with all those moving parts. I've just never noticed it before, but I did have my head down there pretty close to the lower unit when I was greasing the gimbal bearing while it was idling with the muffs on. The only area I heard any noise from was from the very top on the outdrive, where the input shaft ends and is geared to the vertical shaft. Maybe I'm being overly cautious?
    Old 06-01-2016, 07:29 PM   #6
    blockp's Avatar
    blockp is currently offline
    My Model: 99 Jubilee 214
    Gallery Images: 8
    Send blockp:
    My bravo 3 (first one I've owned) is definitely louder than any of the alpha's or even {cough} cobra's I've owned in the past. First time I noticed that noise, I started looking at prices of upper gear sets and rebuilding the drive. Same thing as you, sound is right at the upper cap area, I only notice it on the trailer, nice and quiet in the water. No noise when turning or trimming up.
    I started by changing the gear oil... it was clean with no metal or water intrusion. Then decided to run it till it blew or started getting worse. 3 years later, it still sounds the exact same. Since then, I've talked to a handful of bravo 3 owners that have said it's normal and theirs sounds the same.
    Old 06-02-2016, 02:02 PM   #7
    Send Txtruckerpaul:
    thanks for the input, blockp. Maybe I'm just being paranoid about blowing the unit up and having to break the bank to buy a new lower unit. I've seen an exploded view diagram of the bravo 3 and with that many moving parts, there's bound to be a little noise coming from the unit. I'll just stop worrying about it and enjoy leaving bayliners in my wake, lol
    idling noise soccersteinr Mercury MerCruiser 4 08-14-2014 04:32 PM
    Bravo three ticking noise Txtruckerpaul Mercury MerCruiser 1 06-11-2014 06:39 PM
    bearing noise? num12 Mercury MerCruiser 11 05-08-2014 02:50 AM
    alpha one noise mwads275 Introductions 5 09-24-2010 12:53 PM
    Beeping Noise??? llcelebrity Original Mariah Talk 3 08-13-2009 04:34 AM
    There are 206 users
