Knocking and vibrations
Old 05-23-2016, 01:00 AM   #1
zugzug's Avatar
zugzug is currently offline
My Model: Z320
Send zugzug:
Default Knocking and vibrations
Well, 2nd day out this year and my 7.4/454 1995 Talari has some serous issues. It starts up just fine and no problems at idle. As soon I I get to 2000+ RPM's it sounds awful. Thought is was the u-joints on the bravo 3 but now I think it my be both u-joints and a rod in the motor. Anyone have any advice? Going to take off the bravo 3 this week or weekend to check things out there. Maybe my knock is only there but it sounds crazy bad past 2K RPM and I suspect engine issues as well. 326 hours on the boat and motor but usually under full load of capacity and 4500/4800 RPMS. I made it back to dock under its own power but at only 1500 RPM. Pontoons even passed me, GRRRrrrrrr.
I would also be interested in where to buy a new long block. It changing the engine in a boat extremely difficult? I am pretty good mechanically, put a small block in a Toyota 4x4 back in my youth. Where is a reasonable place to buy a engine. I would love to go with a HP 396 or 427 but dont know the differences of what a boat will accept compared to a car/truck.
Appreciate the read and any advice. Can't imagine getting rid of my Mariah so I am looking forward to advice and encouragement. A little hoppy cam with the captains call would make the Baja folks jealous.
2001 Mariah Z302ST Shabah
1995 Mariah Z240 Talari (For sale soon.....)
  • Old 05-23-2016, 02:03 AM   #2
    jarwiebe's Avatar
    jarwiebe is currently offline
    My Model: Z210 Shabah
    My Engine: 5.7 LX Alpha I
    Gallery Images: 2
    Send jarwiebe:
    Default Re: Knocking and vibrations
    Your symptoms sound similar to what I experienced a few years ago. I did the same as you, came back to port under my own power at about 1500 rpm (about a 10 mile cruise). Mine ended up being a blown head gasket between cylinders 6 and 8. A quick way of checking is by doing a compression check. I had sever cylinder scoring on the 2 cylinders and decided to go the long block route rather than over boring. Went with the same 5.7L as the boat had come with originally. Sorry can't help you with sourcing a long block as my local mechanic sourced it for me.
    Cheers
    Jake
    1996 Z210 Shabah
    Mercruiser 5.7LX
    Alpha One Drive
    80 Lb. SX Smart Tabs
    Old 05-23-2016, 11:35 AM   #3
    rick182 is currently offline
    My Model: 182
    My Engine: 4.3L
    Send rick182:
    Hello,
    I am new to boating. But have been worked on a few car engines. If it is a rod it does usually happen at a specific RPM like you explained. quick way to tell is pull the dip stick the oil will have a metal flake in it like a nice flake paint job.
    Good luck
    Rick
    Knocking noise in back of engine. Help!!!! TomFasig Mercury MerCruiser 6 09-18-2013 06:20 AM
    Knocking sound while turning Captain D Original Mariah Talk 7 08-24-2009 04:35 PM
    There are 232 users
