correctly reading the engine oil level
Old 10-28-2015, 04:26 AM   #1
m&mmariah is currently offline
Status: Gold Contributor
My Model: 180 Shabah
My Engine: 4.3 Mercruiser 4v carb
Send m&mmariah:
Default correctly reading the engine oil level
Hi all;
I finished winterizing a couple of days ago, which included an engine oil change (4.3 Mercruiser, 4.5 qt. oil capacity). I always check the oil level after I've changed it, but I'm not quite sure if I'm doing it correctly. I do my best to try to level the boat, using a bubble level on the boat floor in order to get an accurate dip stick reading. Here's my question: Should I be using the boat floor as my level reference, or the swim deck, or the flat top of the flame arrester? Or, is the dip stick marked to be read when the boat is actually in the water?
Thanks for any advice!
  • Old 11-04-2015, 02:46 PM   #2
    Default Re: correctly reading the engine oil level
    As far as I have read: boat on the water per the manual. I suppose one could level the waterline while the boat is on the trailer. Just answers I found on other boating forums.
    Old 11-05-2015, 05:47 AM   #3
    Send m&mmariah:
    Thanks for the reply.....I really appreciate the help and advise. What you said makes good sense to me, as being on the water is the boat's normal operating environment. So, when the oil reads at the "full" mark on the dip stick, I can be sure it's got 4.5 quarts in and it's an accurate reading.
    What octane level gas should I use? Lakeside Mercury MerCruiser 7 04-19-2013 02:25 PM
    Water Level Petition 300sflyer Boating 101 1 09-07-2010 01:35 PM
    when to check oil level. pimpadelic Mercury MerCruiser 1 08-22-2009 03:19 AM
    Can't get the daggone boat to load up correctly! GRRRR LluberesMM Trailering and Tow Vehicles 13 08-02-2009 03:09 PM
    4.3L V6 Oil Dipstick Reading? SEMIJim Mercury MerCruiser 3 07-14-2009 10:23 PM
    There are 299 users
