Up the creek?
Old 07-15-2015, 09:28 PM   #1
ledacious is currently offline
My Model: Z204 Jubilee
My Engine: 5.0L
Send ledacious:
Default Up the creek?
I didn't winterize correctly and now I have a cracked block and a crack foot (lower unit)! I have a 2000 Mariah Jubilee with a 5.0 Mercrusiser... Should I call it quits or is there a way to fund a used motor and pay someone to put it in?[emoji24] [emoji23]
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Thank you ledacious for this useful post!
jjt1276 (08-25-2016)
  • Old 07-16-2015, 03:36 AM   #2
    Default Re: Up the creek?
    Why of course there is... you could get a 2nd job, become a sex toy for old men or hang out the red light and hope for the best.
    99 Mariah 258 and Firestone like this.
    Old 07-17-2015, 06:16 AM   #3
    rainman55343 is currently offline
    My Year: 2003
    My Model: sx 19
    My Engine: 5.7 alpha 1
    Send rainman55343:
    The last owner on mine didn't winterize mine right either. Had a 5.0 in it and a cracked block. Cost me 4000 for a new motor. I put a 5.7 in it. Was the same price as the 5.0 and the 5.7 is a way better motor.
    Old 07-17-2015, 04:07 PM   #4
    Agreed. If you are going to repair or replace, now is a good time to upgrade to a 5.7. Basically the same fuel economy with more HP.
    rainman55343 and Firestone like this.
    Old 07-17-2015, 06:41 PM   #5
    My Engine: 5.0L
    Send ledacious:
    Thank you Rainman and MikeyT.... I was wondering about that. So did you get a rebuilt 5.7 or a brand new engine? Did you get it from a Mercruiser dealer or find one on-line?
    Old 09-29-2015, 09:03 PM   #6
    Michaels1956's Avatar
    Michaels1956 is currently offline
    My Model: 2000 ZC
    My Engine: 5.7/V8 Alpha One
    Gallery Images: 4
    Send Michaels1956:
    I had a cracked block on my new boat last year (2014) and I found a used 1996 5.7 complete engine (443 hrs) with enclosed heat exchager system. This system is replacing my old block with no heat exchanger and dated 1992. I don't know why your outdrive got cracked when the water runs out anyway? My new installation has blue drain plugs on the exhaust manifolds and exchanger near bottom of engine suction side of lower unit. If I drain the locations and run the areas dry I should not have any issues. My block is antifreezed and I have aluminum exhaust manifolds to prevent rust internally. I got my engine from Craigslist out of Washington State and I live in Alaska. :-)
    Sent from my SGH-I317M using Tapatalk
    Old 10-19-2015, 06:59 PM   #7
    My Model: 2000 ZC
    Gallery Images: 4
    Send Michaels1956:
    So did you find a used engine to replace the old one? My 5.7 engine cost me $2500, and I installed it and repaired all that needed fixing. :-)
    Old 08-03-2016, 06:32 PM   #8
    kdcox1962 is currently offline
    My Model: 244 jubilee
    My Engine: 5.7 mercruiser
    Send kdcox1962:
    We are wanting to winterize our 98 jubilee ourselves since we are not satisfied with our current boat mechanic. Is there a guide somewhere on the correct procedure?
    Old 08-04-2016, 02:55 PM   #9
    My Model: Z276
    Send Brian Belcher:
    Long block is $2100. New/reman.
    Another option is a junkyard motor. It's a Chevy 305. I can get a price from my local boat wreaking yard for you
    Old 08-07-2016, 03:42 PM   #10
    zluvr is currently offline
    Gallery Images: 1
    Send zluvr:
    depending on the block damage, repair might be a lower cost option if you have a company in your area that does this? Cast Iron Repair Engine Applications - Turlock, CA - LOCK-N-STITCH Inc.
    There are 341 users
