water in buldge
Introductions
Old 02-07-2015, 04:13 PM   #1
etheltaylor is currently offline
My Model: 221
My Engine: 4.3 V6
Send etheltaylor:
Default water in buldge
floor storage will not drain can any one help
  • Old 02-09-2015, 03:07 PM   #2
    Default Re: water in buldge
    If your boat is on the trailer, crank the jack up to raise the bow up higher. This will cause water to naturally run to the stern. Go pull your drain plug and let it flow out. If the water still remains in your storage area, you may have a clog in the drainage line. You can use a coat hanger or larger pipe cleaner to run it through the hole and clean it out. Hope this helps
    Water in the oil Chris B Mercury MerCruiser 0 12-06-2014 08:28 PM
    Water dam in the hull? jetinspector Original Mariah Talk 2 03-30-2014 05:24 AM
    4.3 LX Water in oil jb57 Mercury MerCruiser 19 09-23-2013 12:35 AM
    First Water Run!! truckingeorgia79 Original Mariah Talk 9 02-20-2012 08:07 PM
    how much water do you take on? bpfirrman General Maintenance 7 04-29-2008 09:35 PM
    Total Threads: 13,324
    There are 428 users
