-   -   New owner (http://www.mariahownersclub.com/forum/introductions/9659-new-owner.html)
Dep891 07-21-2014 02:22 PM
New owner
Hello all. Just per chased a 1998 Z240 Talari. Bilge is not working. Is it possible that the fuse is blown?
mikeyt 07-21-2014 05:28 PM
Re: New owner
First off, welcome aboard!. Second, the site search function at the top right of your screen is your friend here on this site and this is a very common problem discussed here many times.
Yes the fuse could be 'blown' but its just as likely the wiring connections at the bilge pump need to be disconnected, cleaned & reconnected. Use a volt meter and see if you have 12v at the pump. Here is a link to just one of many recent threads discussing that very problem.
